WTB -Wheel Stud..s
I am looking for longer wheel studs. I only need 2.
what length and thread pitch
i can get them in 4 packs made by ARP
For focus 12x1.5 i believe. Any length. I just need longer, so i can put washers too see thickness of spacer i need.
Measure it from tire to fender
(08-17-2013, 01:21 PM)GFXjamie Wrote: Measure it from tire to fender
it is not that easy.
my wheels are already +25, i actually need longer stud and washers to see if wheels/tires are scraping or not when turning.
rear one, i am going with axle spacer, so that is not a problem.
Just please don't drive on 2 studs and washers lol
+25 I doubt you are rubbing inner fenders unless you have huge tires
actually +25 is not a problem but look at my riding height.
car is already 3"+ dropppd and i am running slightly larger tires. 225 40 18.
it already had rubbing issue but got away with BFH.
i am going to order from ebay uk.
i found m12x1.5 and gives me an info saying it is 20mm longer than stock studs.
but i still need to find out a knurl diameter from stock studs.
