Threads: 11
0
03-01-2010, 03:28 PM
(This post was last modified: 03-01-2010, 03:30 PM by bmxfu.)
I had noticed that my front wheels are toed into the wheel well's, so i figured i would just take it to the local dealer up the road from me and see what they had to say. They told me it was my ball joints, The reasoning for it happening would be from lack of maintenance. I clean an grease my ball joints every 10k km so theres no lacking there. I do live in an area with very crappy roads and harsh bump's so im thinking could this be the reason? That is all irrelevant now as i do need to replace them. what would i be looking at for cost on two lower and two upper ball joints? and would i be better just getting them installed or just taking the time to do them myself?
Threads: 401
Had mine done a couple of years ago. You can't just replace the ball joint itself. You have to do the lower control arm, at least according to Ford. Cost for parts was around $400.00
2000 White ZTS: retired
K&N Filter.....
Threads: 18
0
a parts store here in Barrie quoted me 35$+tax for a Focus ball joint . You just have to grind and drill through the rivets and install the part with the bolts and nuts .
Threads: 15
0
I did the lowers on my 2000 what a PITA, when Ford pressed in the rivets they mushroomed on the inside of the control arm so its not just a matter of cutting off the top of the rivet and hammering the rest out, Have fun
Threads: 5
0
I need to replace mine as well. A lightsaber would come in handy for going the DIY route.
