Garage Sale - Check It Out
I promised my wife we’d park both cars in the garage this winter ... so I have to clear it out.
** UPDATED MONDAY FEB. 16TH - 10:00 AM - SOLD ITEMS REMOVED, PRICE REDUCTIONS**
Pics below the list:
3) Hella FF50 Driving Light Kit – NEW – (cost $100) – 35.00
4) Complete 07 wagon suspension – springs have just 4k, dampers have 40k – will fit all Focus wagons – 8-pcs - 140.00 ** REDUCED TO JUST $60 FOR ALL FOUR CORNERS !! **
9) 05-07 Focus grill – chrome surround on silver insert – Virtually new (Take-off) – 35.00 ** REDUCED TO JUST 20.00 !! **
14) 4-Motorcraft SP448 spark plugs – Duratec - NEW (compare at 82.00) – 41.00 **REDUCED TO JUST 30.00 FOR THE SET **
15) 4-Motorcraft SP478 spark plugs – Zetec - NEW (compare at 52.00) - 26.00 **REDUCED TO JUST 20.00 FOR THE SET **
18) 2-OEM Ford rotors 05+ - 20k, lots of meat left – I replaced them with Brembo, they ran true when I had them on - 20.00** FREE TO GOOD HOME (includes pads) - COME PICK EM UP**
FREE STUFF ADDED
Complete wagon OE Duratec exhaust - from 07 very low km - was cut into 3 pcs for removal prior to MBRP install **FREE TO GOOD HOME - PICK UP ONLY**
Wagon retractable rear compartment cover - silver - perfect condition **FREE TO GOOD HOME - PICK UP ONLY**
Dibs on the following items:
6) Rear camber adjuster bolts – SPC 81310 – NEW (cost $70) – 25.00
8) Moog HD front end links, pair – NEW – K80066 – 35.00
12) 4-Motorcraft oil filters – FL400s Zetec – 10.00
I will PM for further details.
Ivan MacKenzie.
Old Ride: 2001 Malibu Blue MTX Street Edition Wagon
New Ride: 2010 Mocha Brown MT 2.0T Passat Wagon
What size are the centre caps? Would they fit on my S2 wheels?
BUMP for a great seller!
Steve
1999 ZX2| MX3 H&Rs | S/R Tokicos | 21mm RSB | ES Bushings | HotShot CAI | Knocker mod | MSD Coil & 8.5mm Wires | SCT | B&M SS | SpeedHut Gauges | 16" BSA 303s
Coming soon: FR UDP | Pacesetter Shorty Header
Less is more... "Simplify and add lightness"
Click Here to E-mail Me!
Click here for my eBay auctions
lowblackdub,Sep 29 2008, 12:31 AM Wrote:What size are the centre caps?  Would they fit on my S2 wheels?
[right][snapback]273494[/snapback][/right]
Hey Steve ... not sure of the exact size (I can measure if need be) but I know for a fact they fit the multi-spoke 15" alloy wheel, as well as the standard 16" alloy rims ... they also fit the 15" Mystique rim which is identical to the S2 rim (except of course for diameter) ... 99% sure they would fit the S2 rim.
PM'ed about 21mm rear sway
ZTWsquared,Sep 29 2008, 04:59 AM Wrote:Hey Steve ... not sure of the exact size (I can measure if need be) but I know for a fact they fit the multi-spoke 15" alloy wheel, as well as the standard 16" alloy rims ... they also fit the 15" Mystique rim which is identical to the S2 rim (except of course for diameter) ... 99% sure they would fit the S2 rim.
[right][snapback]273496[/snapback][/right]
Could you measure for me? You wouldn't by chance be willing to part with just one?
Steve
lowblackdub,Sep 29 2008, 11:18 PM Wrote:Could you measure for me?  You wouldn't by chance be willing to part with just one?
[right][snapback]273569[/snapback][/right]
I'd like to try and sell the set first ... measurements are:
Total outside diameter = 2.75"
Diameter between the outside edges of the clips on backside = 2.125"
Interested in the lugs and center caps. Will the caps fit these wheels?
[Image: 12b121133ZZZZZZZZZ89t468168fc505c194a.jpg]
Will take the lugs.
svtcanuk,Sep 30 2008, 09:26 AM Wrote:Interested in the lugs and center caps.  Will the caps fit these wheels?
[right][snapback]273585[/snapback][/right]
The centre caps I have are what came with those rims ... exact and perfect match. I wouldn't recommend the lugs for OEM rims though.
Edit: the tuner lugs are too small for OEM rims ... however, if you take the centre caps I will throw in 16 OEM lugs - not primo, but not bad either.
hardk0re,Sep 30 2008, 09:35 AM Wrote:Will take the lugs.
[right][snapback]273586[/snapback][/right]
Thanks Kevin - second dibs - see above.
I'm thinkin on that front lip. Painted or plain plastic.
Scorcher000,Sep 30 2008, 11:09 AM Wrote:I'm thinkin on that front lip. Painted or plain plastic.
[right][snapback]273597[/snapback][/right]
More details on the link that I posted John ... but essentially primed fiberglass (beige-ish) - needs to be painted. PM sent.
[right][snapback]273591[/snapback][/right]
Let me know when we can meet up for the caps, you know where I live so getting together shouldn't be too difficult.
[right][snapback]273627[/snapback][/right]
PM sent.
You're first in line now, if you still want them.
Thanks for the center caps and the conversation.
svtcanuk,Sep 30 2008, 11:30 PM Wrote:Thanks for the center caps and the conversation.
[right][snapback]273656[/snapback][/right]
Good to meet you Rob - you should bring the CSVT out one Monday night, I know the guys would be interested in seeing it.
Also: PM sent
Ken, if you sent a PM I did not receive it.
Okay - this is now confirmed by both actual measurement and by tech experts I spoke to in the US ... the wagon rear sway bar (and the Street Edition rear bar BTW) is the same as the SVT rear bar ... all at 21 mm.
Canadian ST,Sep 29 2008, 02:32 PM Wrote:PM'ed about 21mm rear sway
[right][snapback]273534[/snapback][/right]
  Focus garage sale! MikkelRS 3 2,491 01-21-2016, 11:31 PM
Last Post: MikkelRS
  Garage sale thread. castone 4 3,586 01-11-2012, 02:42 AM
Last Post: JMCustoms
  Movember Garage Sale hardk0re 15 7,864 01-08-2012, 01:55 PM
Last Post: hardk0re
  Garage Sale Part 1 hardk0re 10 6,111 06-28-2010, 04:49 AM
Last Post: hardk0re
  Garage Sale hardk0re 12 6,040 02-04-2010, 11:18 AM
Last Post: 2009SEL
  Final Garage Sale Blackzx3 14 8,675 05-21-2008, 03:13 AM
Last Post: BananaClipper
  Garage Sale ! Mike 46 21,371 05-07-2008, 01:41 PM
Last Post: silvermist
