Wtb: Suspension Oem/aftermarket Urgent
Well,
Ran into some problems with the ford. My spring apparently is broken.
Both front ones too.
I need OEM Springs and Struts perferabbly or aftermarket.
Let me know. My car is at shop atm, and I wanted to source out with you guys first before buying some expensive stuff from autowreckers and such.
Let me know.
Ryan
Edit. This is for a 2000 LX model focus.
BananaClipper,May 20 2008, 01:08 PM Wrote:Well,
Let me know.
Ryan
[right][snapback]264677[/snapback][/right]
What year ? IIRC nefcanuck as an '05 suspension for sale
Should have clarified.
First post updated :( To bad 05 won't work.
Quick question. I assume 00-04 suspension all same? IE hatch will fit my sedan?
I already responded to a few ppl on classifieds. Hoping some of you have some stock stuff laying around and are too lazy to post in classifieds since most people arn't looking for stock stuff :P
BananaClipper,May 20 2008, 01:43 PM Wrote:Should have clarified.
[right][snapback]264683[/snapback][/right]
Yes - sedan susp will fit hatch .. also: if replacing both springs and struts, the '05 suspension will fit 00-04 ... 05+ springs will not fit on 00-04 struts.
Let me know.
Ryan
Check first with Ford to see if they are still under recall for faulty springs. It's a 10 year, or a ton of kilometers covered. Unless you want to replace with lowered springs.
2000 White ZTS: retired
K&N Filter.....
Let me know.
Ryan
[right][snapback]264688[/snapback][/right]
Did not know this. Thanks for this. Will call them now.
Hopefully will come through here.
Edit... Do you have a back up for this?? I can't seem to find it anywhere on internet?? Or should I just call them and they should know what I'm talking about?
[right][snapback]264685[/snapback][/right]
Hmm.. never knew this. Upper mounts and such are all the same I assume? If I replace springs/struts 05 will fit then eh? Something to consider.
Yes the ford springs are still under recall for the 00-04 focus unless you have already claimed it once. and if you go to the dealer the alignmnt should be included in the recall. so ask before hand and make sure if they say yes that it gets done. ask for the print out cause the tech only gets payed 0.2 hrs i think for a recalled alignment so he might not want to do it.
phased_focus,May 20 2008, 03:51 PM Wrote:Yes the ford springs are still under recall for the 00-04 focus unless you have already claimed it once. and if you go to the dealer the alignmnt should be included in the recall. so ask before hand and make sure if they say yes that it gets done. ask for the print out cause the tech only gets payed 0.2 hrs i think for a recalled alignment so he might not want to do it.
[right][snapback]264695[/snapback][/right]
The wife had the front springs replaced in her 01 last year, they did a alignment after for free as well. I think i still owe Nefcanuck a beer for letting me know. :beerchug:
[right][snapback]264697[/snapback][/right]
Well if this works out, I think I owe a few of you a beer if this works out :D
If you do need the suspension parts, lemme know (I'm on vacation so I've got a much looser schedule ATM)
NefCanuck,May 20 2008, 03:21 PM Wrote:If you do need the suspension parts, lemme know (I'm on vacation so I've got a much looser schedule ATM)
[right][snapback]264701[/snapback][/right]
Sounds good, I will hopefully hear back from Ford today or Tommorow. I need something in this car ASAP as it is my DD.
What suspension components do you have? Springs/Struts? Or one or the other?
Let me know.
Let me know
[right][snapback]264704[/snapback][/right]
I have the whole shooting match front & back (I had replaced the stock setup with the SVT suspension kit last year, about 52,000 on it when it was swapped out)
Yeah they should still be under warrenty...
My mom's 03 zx5 just had the fronts replaced for free!
Which was too bad..... i wanted to do a bit of a drop on hers, at least and SVT set up
P.s. i never heard back from you about those rims? still interested
2002 pitch black ZX3
__________________
Classic Painting
I appreciate all the quick responses and help. Honestly if I didn't post this I would have never of known this was warrenty covered / recall.
Glad I got this fixed :D. Beer for all :ph34r:
  Wtb - Suspension! Urgent konafocuswrc 4 2,326 05-17-2008, 09:57 AM
Last Post: konafocuswrc
