Start Button - Now With Pics 24/5/08
so i want to add a start button, i figured im going to just drill a hole in the radio bezel and run the wires from there. that way i still have my 12v outlet. anyway does anyone have any pics of what wires i wire it into for the igition?
i Have one... haven't insatlled it yet
Got mine from here.... http://www.performance-pcs.com/catalog/ind...oducts_id=22160
What i plan on doing is putting mine where the 12v lighter is and relocating the lighter elsewhere in the shifter console (like the SVT has)
Instructions off FF
http://www.focusfanatics.com/forum/showthr...&threadid=66373
2002 pitch black ZX3
__________________
Classic Painting
thats much better pricing than the GT40 one i saw for like 100+ lol, did you need to buy a relay or something? i keep seeing people who are using the honda s2000 get a relay.
i m using s2000 button w/ relay
I use my key
Canadian ST,May 16 2008, 07:00 PM Wrote:I use my key
[right][snapback]264527[/snapback][/right]
LMFAO. Me too. :lol:
2008 Taurus X to be modded.
Still The Weakest LinkBlush
If I really want to I just use the remote starter (Still have to stick the key in the ignition, but the key seems to go in much smoother then :blink: :lol:)
i know a few of you guys have done it....i hope zx3_2nv looks here lol..
its not that complicated but the details on FF aren't that clear. also i need to know if i need a relay or not.
if you get the one from performance pc's you dont need a relay. i have the green one off that site. it was 22 or 23 $$ shipped to my door. pm me here or on focus fanatics if you need any more help.
zetec crew #200
If you can chop your own wood you will warm yourself twice
Zetec: Its always on
I've done it... its a simple two wire install... Its the Grey /Black and Red wire in the steering column that you attach your push button to.. I got mine off of Ebay... i paid 25 - 30 bucks for it something like that. i think i have the same one as ZX3_2NV..
Yeah no relay needed.. really simple install i highly recommend you solder the joints though.. well you should solder ALL wires but especially these ones.. Its a cool mod i dont use mine on a day to day basis mainly when a freinds in my car or i'm showing off some were...
Professional Certified Nut Case...
oh thats great. so now which wire goes to which terminal on the switch? lol im about to place the order :lol:
Spinal,May 17 2008, 10:56 AM Wrote:oh thats great. so now which wire goes to which terminal on the switch? lol im about to place the order :lol:
[right][snapback]264557[/snapback][/right]
Shouldn't matter if it's a 2 wire switch. It's simply making a connection, and you release it when the engine starts, same as you would when using the key.
No comment
:lol:
many thanks to faster_than_u for the help, and anthony i dont get the point of that comment....if you tried to be funny you failed, at least for me :rolleyes:
no problem man. let me know if you need any more help
zetec crew #200
Spinal,May 17 2008, 04:09 PM Wrote:and anthony i dont get the point of that comment....if you tried to be funny you failed, at least for me :rolleyes:
[right][snapback]264571[/snapback][/right]
I suspect that he was either being sarcastic about where to put the 2 wires on a 2 wire switch.....or.......the mention of using keys to start it :lol:
interestingly enough it has 4 pins not 2 :ph34r:
Well, you'll only need one 'pole' of it to start the car. Use a multimeter to tell you which poles make the circuit when the button is pushed in.
here is my 4 yrs old how to i did..
http://forums.focaljet.com/interior-modifi...ction-here.html
The switch i have is only two pole.. all it does is it simply bridges the connection between the two wires... But then again it does depend on the switch you get so its best to consult with the instructions included to be 100% sure...
It is an easy hook up.. it took me 15 minutes to do mine and i soldered everything..
  Push Button Start? AckermaNzx3 7 3,419 05-20-2009, 07:43 AM
Last Post: AckermaNzx3
