Wtb: Focus Shorty Antenna
could some one point me in the right direction on where to get one. ether new or used.
also i have a serious sat radio and where would i find the cord to hard wire it to my stock cd player. i have to 6disk in dash changer.
thanks
2000 yellow zx3 sold
1994 mazda mx3 sold
1992 ford festiva (RIP)
make your own.
Take your current antenna, a good set of snips and cut off about 8" of it.
Heat up the end you cut off and remove the dressing off the top.
apply to the end you will attach back on the car.
It looks a lot better than any shorty out there.
Look it up.
HACK
ya i did that on my zx3. i guess i could do it agane.
1994 mazda mx3 sold
To hardwire your Satellite Radio, you will need an auxillary input converter. I used the P.I.E. FRD-04. The unit has two standard RCA jacks and a cable that connects to an input connector on the factory head unit. It needs to be wired in to +12v. I use one with the Onyx XM radio. You can also hook up an Ipod with it, it simply adds an aux jack. You will not be able to use the headunit controls to control the satellite radio however.
Crutchfield.ca has them for $109, I found mine used on Kijiji for $50. It works great and sounds WAY better than the FM transmitter on the satellite radio.
http://www.crutchfield.ca/P_I_E_FRD04_AUX_.../469frd4aux.htm
  Wtb: Shorty Antenna NOS2Go4Me 11 3,525 09-01-2007, 09:20 PM
Last Post: zx5power
  Wtb Shorty Antenna wpgzx5 9 3,056 06-08-2005, 12:33 AM
Last Post: wpgzx5
