11-16-2007, 10:56 AM
Just noticed with the cold/wet weather I've got a bit of a slight squeak coming from the passenger side of the engine bay. From my readings it seems like there's no way to manually tighten the drive belt and that the only way to tighten it is to purchase a new tensioner. Is this correct? Or is there a bolt I can twist somewhere (on the tensioner?) that will tighten the drive belt and cure me of the mouse like noise under my engine?
Use to drive an Eagle Talon so this whole concept of automatic tensioners is totally new to me.
