September 26, 2007
Ottawa, Ontario - Transport Canada has issued its latest recalls, which may affect some Ford, Jeep, Nissan, Dodge and Volkswagen vehicles.
2005-2007 Ford Freestar
Vehicles affected: 252
On certain vehicles, the daytime running light (DRL) system is inoperable. Normal headlamp function is not affected. Dealers will reprogram the electronic module to activate the DRL function.
2007-2008 Jeep Commander
2007-2008 Jeep Grand Cherokee
Vehicles affected: 1,400
On certain vehicles, the front brake calipers were improperly manufactured and could break under certain operating conditions. Dealers will inspect and, if required, replace the front brake calipers.
1997-2001 Infiniti QX4
1997-2007 Nissan Pathfinder
Vehicles affected: 45,039
On certain vehicles, inadequate coating of the fuel filler tube assembly could allow water to penetrate past the coating, and cause surface rust. In areas which use heavy concentrations of road salt, corrosion may occur to a degree which results in perforation of the tube. Dealers will replace the fuel filler tube assembly.
2007 Dodge Ram
Vehicles affected: 150
On certain 2WD trucks equipped with a manual transmission, the driveshaft yoke may break. Dealers will inspect the driveshaft.
2007 Dodge Nitro
2006-2007 Jeep Commander
2006-2007 Jeep Grand Cherokee
2007 Jeep Wrangler
Vehicles affected: 29,500
On certain vehicles, software programmed into the antilock brake system (ABS) electronic control module may allow a momentary delay in braking when coasting up a hill during certain conditions. Dealers will reprogram the ABS module with updated software.
2006-2008 Volkswagen GTI
2006-2008 Volkswagen Jetta
2006-2008 Volkswagen R32
2006-2008 Volkswagen Rabbit
Vehicles affected: 50,000
On certain vehicles, a required cap designed to disable the headlamp horizontal aim may not have been installed during vehicle assembly. A cap may have been inadvertently installed to disable the vertical aiming screw. An adjustment mechanism allows aiming the low beam relative to the high beam. Dealers will affect repairs.
Wasn't the Freestar made in Oakville? Perhaps one of our members did a few DRL Mods on the Freestar? :lol:
Note to "our guys in Oakville", just kidding. No offence intended.
2000 White ZTS: retired
K&N Filter.....
252 jobs divided by (roughly) 350,000 Freestars produced, means one in 1389.
Or .07%.
That means you can cast the first stone if you do everything in your job 99.93% correct in 3 years. ;)
But if you want the most correct answer, modules come into the plant pre-programmed.
Or .07%.
[right][snapback]249656[/snapback][/right]
Honestly, I understand that all vehicles can have something go wrong along the line during production. I knew it was a computer problem, I was just trying to make a joke, especially with the fact that some of us have done the DRL mod on our Focus's
K&N Filter.....
oldeguy,Sep 27 2007, 12:24 PM Wrote:I was just trying to make a joke,[right][snapback]249659[/snapback][/right]
I know, that's why I put the "wink" smilie in.
Good I don't need anymore Ford people pissed off at me :lol:
K&N Filter.....
  Transport Canada issues latest recalls Frost__2001 1 2,246 09-29-2010, 01:52 PM
Last Post: reldridge
  Transport Canada announces latest recalls Frost__2001 1 2,411 08-19-2010, 02:34 PM
Last Post: Spinal
  Transport Canada issues latest recalls Frost__2001 2 2,480 07-17-2010, 12:02 AM
Last Post: NefCanuck
Information Transport Canada issues latest recalls Frost__2001 7 4,398 06-12-2010, 04:01 AM
Last Post: Mystake
  Transport Canada issues latest recalls Frost__2001 3 2,567 05-06-2010, 11:12 AM
Last Post: mo_focus
  Transport Canada Issues Latest Recalls Frost__2001 1 2,291 04-20-2010, 11:36 AM
  Transport Canada Issues Latest Recalls Frost__2001 7 3,833 03-31-2010, 01:37 AM
Last Post: Mystake
  Transport Canada Announces Latest Recalls Frost__2001 4 3,081 02-25-2010, 11:31 PM
Last Post: Scorcher000
  Transport Canada Issues Latest Recalls Frost__2001 0 1,912 02-10-2010, 10:22 PM
Last Post: Frost__2001
  Toyota Recalls 2.3 Million Cars In Canada And U.s. darkpuppet 15 7,543 02-03-2010, 02:53 AM
