Transport Canada releases latest recalls
August 17, 2007
Ottawa, Ontario - Transport Canada has issued its latest recalls, which may affect some Honda, General Motors, Ford and Mazda vehicles.
2007 Honda Civic
Vehicles affected: 1,387
On certain vehicles, the Tire and Loading Information Label was printed with incorrect Gross Vehicle Weight Rating (GVWR) and Gross Axle Weight Rating (GAWR) data. The information printed on the affected label is that for the Civic LX model, which weighs less than the Civic EX model. The incorrect labels indicate a GVWR of 1665 kg, which should be 1695 kg; a front GAWR of 880 kg, which should be 895 kg; and a rear GAWR of 785 kg, which should be 800 kg. Since it does not pose any safety risk, no corrective action is required.
2006-2007 Chevrolet Optra
Vehicles affected: 9,120
On certain vehicles, a piece of the seatbelt buckle lower cover may break off and become lodged in the buckle assembly. As a result, the seatbelt tongue may not latch in the buckle or the push button may become stuck, preventing the occupant from unlatching the buckle. Dealers will replace the driver and front passenger seatbelt buckles.
1993 Ford Bronco
1992-1998 Ford Crown Victoria
1992-2003 Ford E150, E250, and E350
2003 Ford E450
1999-2001 Ford Explorer
2001-2002 Ford Explorer Sport
2001-2002 Ford Explorer Sport Trac
1993 Ford F150
2003-2004 Ford F150 Lightning
1993 Ford F250, F350, and F450 Super Duty
1995-2002 Ford F53 Motorhome Chassis
1998-2002 Ford Ranger
1993-1995 Ford Taurus SHO
1993-1998 Lincoln Mark VII
1992-1998 Lincoln Town Car
1992-1998 Mercury Grand Marquis
Vehicles affected: 168,524
On certain vehicles, the speed control deactivation switch may overheat, smoke or burn, potentially resulting in an under-hood fire. The failure mode appears to be different than that of Recall 2005028 (05S28); this time, the concern is with long-term durability performance issues causing the switch to fail. Initially, as an interim repair, owners will be instructed to return their vehicles to dealers to have the speed control deactivation switch disconnected. As soon as replacement parts are available, owners will be instructed to return to dealers for installation of a fused wiring harness.
2007 Chevrolet Express
2007 GMC Savana
Vehicles affected: 1,812
On certain vehicles, the rear brakes may still be applied, although the brake pedal is released and the stop lamps are no longer illuminated. Dealers will reprogram the anti-lock brake system module.
2007 Chevrolet Equinox
2007 Pontiac Torrent
Vehicles affected: 149
On certain vehicles, the passenger sensing system may fail to detect a small adult occupying the right front seat, due to an error in seat sensor calibration. In the event of a crash severe enough to activate the airbags, the front passenger airbag may not deploy. Dealers will reprogram the seat's electronic control unit.
1998-2002 Mazda B2300
1998-2002 Mazda B3000
1998-2002 Mazda B4000
Vehicles affected: 4,979
On certain vehicles, the speed control deactivation switch may overheat, smoke or burn, potentially resulting in an under-hood fire. Dealers will install a fused wiring harness designed to eliminate the risk.
  Transport Canada issues latest recalls Frost__2001 1 2,247 09-29-2010, 01:52 PM
Last Post: reldridge
  Transport Canada announces latest recalls Frost__2001 1 2,412 08-19-2010, 02:34 PM
Last Post: Spinal
  Transport Canada issues latest recalls Frost__2001 2 2,480 07-17-2010, 12:02 AM
Last Post: NefCanuck
Information Transport Canada issues latest recalls Frost__2001 7 4,400 06-12-2010, 04:01 AM
Last Post: Mystake
  Transport Canada issues latest recalls Frost__2001 3 2,567 05-06-2010, 11:12 AM
Last Post: mo_focus
  Transport Canada Issues Latest Recalls Frost__2001 1 2,294 04-20-2010, 11:36 AM
  Transport Canada Issues Latest Recalls Frost__2001 7 3,835 03-31-2010, 01:37 AM
Last Post: Mystake
  Transport Canada Announces Latest Recalls Frost__2001 4 3,082 02-25-2010, 11:31 PM
Last Post: Scorcher000
  Transport Canada Issues Latest Recalls Frost__2001 0 1,912 02-10-2010, 10:22 PM
Last Post: Frost__2001
  Toyota Recalls 2.3 Million Cars In Canada And U.s. darkpuppet 15 7,552 02-03-2010, 02:53 AM
