Threads: 96
0
aren't your headers wrapped already?
I'd go without the heat shield .. looks alot better when you can see the headers
Below Average Car Club
Threads: 305
9
still radiates a ton of heat, even wrapped and ceramic coated.
Threads: 269
5
I like it. It matches my floor mats. :D
2008 Taurus X to be modded.
Still The Weakest Link![Blush Blush](//www.focuscanada.net/forum/images/smilies/blush.gif)
Threads: 401
It would look good in my car too. Hardkore, are you getting the hint?
2000 White ZTS: retired
K&N Filter.....
Threads: 71
0
what is that big log right behind the cone filter?
Threads: 305
9
It is air/water. I've got the 8" IC barrel, then a pump that pumps the coolant/water mix from a resevoir through a front mount heat exchanger and up through the barrel and back into the resevoir.
Threads: 116
0
looks good and it keeps heat down good job .
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 55
0
06-11-2007, 12:02 AM
(This post was last modified: 06-11-2007, 12:03 AM by Gravter.)
The only sad part of that setup is that your air filter is way uptop and inhaling lots of heat...
Unless you have a hood scoop to feed it fresher air?
P.S. ... I'd still like to have that setup anytime :P
2007 CD Silver ST **** FOR SALE ****
2014 Performance Blue ST **** SOLD ****
2016 Ford Edge Sport Shadow Black
