i just recently bought a 07 ford focus zx5 ses with the gfx and i was wondering what hid's would fit on my car. thanx.
Question
05-21-2007, 08:33 AM
H4 , 9003 is part number
Ford Focus SES ZX5
Blue Underglow, Clear Corners, Shorty antenna, vogtland springs , Rust Module,Truebendz 2.5 ss magnaflow and Fuzion 205/50/16 HRI's TEAM DURATEC # 99
05-22-2007, 09:54 PM
nothing will be made for your car thats for sure, you will have to go through the modification route, which is not recommended for reflector based headlight lenses anyway.
My other ride is your Mom
05-24-2007, 01:01 PM
what size are the foglights?
05-24-2007, 04:07 PM
if you swap in a 'retrofit kit' which is a hid bulb attached to a H4 base you would lose your high beams (i think there are some 'high/low' kits that apparently move the bulb around a bit to mimic the effect of a dual filament bulb) i dont have any first hand experience with any of these retrofit kits myself..
a less expensive route to get more light is to get a higher wattage bulb (say.. 100w) and get a heavy duty wiring harness. i used to run that setup in my focus. a drawback is that it produces a lot of heat, so it might make the lens bubble a little bit near the bulb. total cost is gonna be around $60.. $20 for the bulbs and $40 for the wiring harness
05-24-2007, 09:39 PM
If you are wanting the HIDs and OEM, the only route is a 2000 - 2004 Down grade on your 2005 - 2007 Focus, it's costly and it will give you the right shape for the OEM Mach HIDs for your car.
and by going this route you'll be replacing everything from the front doors forward.
05-25-2007, 08:00 AM
Frost__2001,May 24 2007, 11:39 AM Wrote:If you are wanting the HIDs and OEM, the only route is a 2000 - 2004 Down grade on your 2005 - 2007 Focus, it's costly and it will give you the right shape for the OEM Mach HIDs for your car. good excuse to get a euro front end!
05-25-2007, 01:11 PM
naz,May 24 2007, 06:00 PM Wrote:Frost__2001,May 24 2007, 11:39 AM Wrote:If you are wanting the HIDs and OEM, the only route is a 2000 - 2004 Down grade on your 2005 - 2007 Focus, it's costly and it will give you the right shape for the OEM Mach HIDs for your car. true, but if your going for the real deal the 2005 - 2007 washer bottle is on the passenger side, and the 2000 - 2004 model is on the driver's side, and the Euro washer bottle only comes in one side, unless you melt the bottle to fit the side repeaters.
05-25-2007, 01:31 PM
are u guys that euro that you change all the bottles now? :o
125whp/129wtq 2006 Subaru Impreza WRX with JDM 6 speed 207whp/273wtq Innovative tuned on Mustang dyno (Stage 2)13.9@99mph 320whp/330wtq Innovative tuned on Mustang dyno (Stage 3) 352whp/360wtq Dynojet 13.3@106mph 2004 Ford F-150 Lariat 2008 Honda CBR600RR "Silver Bullet" R.I.P. 2009 Honda CBR600RR "To Punish & Enslave" 2001 Honda CBR F4i Stunt bike "Burn the Rubber, not your soul" 2013 China 90cc dirt bike
05-28-2007, 02:42 PM
NikiterZTS,May 24 2007, 09:31 PM Wrote:are u guys that euro that you change all the bottles now? :o The euro washer fluid bottle has an indent built into it to allow for the fender side repeaters.. the north american bottle gets in the way so you can either modify it or replace it with the euro bottle. But with the 2005+ having the bottle on the passenger side you don't really have the option of swapping to the euro bottle.
06-12-2007, 09:29 AM
guilty,May 27 2007, 11:42 PM Wrote:NikiterZTS,May 24 2007, 09:31 PM Wrote:are u guys that euro that you change all the bottles now?ÃÂ :o anyone have a tutorial on how to install hids on a 07 focus?
06-15-2007, 05:50 AM
paolo,May 22 2007, 06:54 AM Wrote:nothing will be made for your car thats for sure, you will have to go through the modification route, which is not recommended for reflector based headlight lenses anyway. thanx but they do have a kit for my car and its already been installed |
« Next Oldest | Next Newest »
