Mbrp Install Q's
I got my MBRP exhaust the other day. Quick questions for you who have done it.
1. How long does it REALLY take? The instructions say 1 hour, but I tend not to believe it.
2. How big a pain are the bolts going from the flex pipe to the intermediate pipe? Will I need heat/grinder/impact?
3. Can it be done on ramps, or do I have to get the car up on jackstands?
With having the little guy at home now (5 months old and growing), I need all the spare time I can get. If it takes much longer than an hour, off to the shop it goes Wednesday afternoon.
Ryan
Ryan and the Silver Sedan
[Image: 49951.png]
It can be done on ramps,stands.
It should take your 1-1.5 hours depending on the tools. If your bolts are siezed you may need to cut them taking up more time. You also need a sawzall to cut off your old exhaust.
reldridge,May 14 2007, 02:29 PM Wrote:I got my MBRP exhaust the other day. Quick questions for you who have done it.
Did mine in about 3 hours on jack stands in the driveway.
The difficult part for me was the UNINSTALL. Getting that old bolts off. They had to be grinded off. I would STRONGELY recommend you have a grinder available with a small cutting wheel.
Once the old sh!t was off, the install was done in less than an hour.
I would also strongely recommend you also change the flex pipe to a 2.25" version (which is what I did). My old one had holes in it I discovered and I have noticed gains with this setup.
Ps. I'm a computer geek and not a car geek, and I management this one ok.
Yellow 2000 ZX3 - Tinted Windows, SVT Air Intake, MBRP Exhaust, NewEdge Performance 2.25" Flex Pipe, Focus Sport UDP, SVT Bumper, Ford Racing 9MM Wires, K&N Filter, XCal2 ECU Upgrade, Shorty Antenna, Ported Throttle Body
190,000 KM (120,000 Miles) and counting!
Yeah about three hours to do. I had the car on all 4 jack stands. As far as the old bolts go I just used a breaker bar I didn't have to grind them off but I guess it depends how stubborn they want to be.
VF Supercharger Kit (Stage 2)
it would likely take an hour if you had a hoist, air tools and a torch to cut the old crap off.
2007 Screaming Yellow ZX3 5 Speed
or if its a newer car without rusted nuts
Ford Focus SES ZX5
TEAM DURATEC # 99
Ya getting the nuts off at the flex pipe was definately the hardest part of the install. If you've got a sawzall cutting the old exhaust off will be super easy.
Current
09 F150 SCREW 4X4 XTR
Former
Show
Go
One hours worth of not having to do it your self.
An hour is a steal.
2000 ZX3
Well, appointment is made for Wednesday after work... No time to waste doing it myself.
Oh, and since the car has almost 165,000 kms on it, and plenty of salt and snow exposure, I'm expecting rusty nuts, so the torches at the shop will come in handy.
Ryan
[Image: 49951.png]
Well, had my MBRP installed tonight after work. Not bad! 30 minutes to do the install at the shop.
Only thing that I'm not 100% sure on is the rear hanger. Does it go onto the shipping holes, or onto the factory hanger?
Oh, and it only cost me $40 to have it installed... :D
Ryan
[Image: 49951.png]
When i installed mine, I had to use the supplied hanger to hang it properly. If its not raining tomorrow, I'll crawl under there and take a photo or two. It was weird.
Team PITA
To me, it hangs a little too low, but I'm not sure. I could move it up another hole.
Ryan
[Image: 49951.png]
Yes you have to use the hanger with the nut and bolt supplied and bolt it using the hole above the factory hanger. You may have to have somebody push up on the pipe to get it closer to the bumper while tightening the bolt down.
SmokeBCBuDZ,May 18 2007, 12:42 PM Wrote:Yes you have to use the hanger with the nut and bolt supplied and bolt it using the hole above the factory hanger. You may have to have somebody push up on the pipe to get it closer to the bumper while tightening the bolt down.
[right][snapback]238898[/snapback][/right]
Ok, makes sense. Sounds like something to do on Victoria day Monday! :)
Ryan
[Image: 49951.png]
  Mbrp Install Question. SmokeBCBuDZ 5 2,086 02-16-2007, 11:10 PM
Last Post: 02_svt_guy
  Mbrp Ordered, Install Date July 6 In Huntsville NefCanuck 42 13,132 07-11-2006, 09:11 AM
Last Post: NefCanuck
