Trouble Starting Fixed
Hey everyone again, thanks for your last help, now I have another problem.
2000 Focus ZX3 auto
My problem: The car starts great now, but now after driving for a bit and I put the car in N or P sometimes it stalls out, sometime it almost stalls, and sometimes it's fine. The idle only drops in P and N, D and R are fine, the idle kicks up when you put it in D or R. Where should I look first. I have no problems mechanically it's just my diagnosing skills are weak.
thanks in advance.
DRyanC
2000 Black ZX3 (sold)
2007 Liquid Grey ZX5 ses (sold)
2007 CD Silver ZXW ses
2013 F150 crew xlt 4x4 blue flame
idle should go up a bit in p or n, i didn't say porn..
Well I was at Crappy tire and pick up a set off plug to start. This is my 4th set. only have 120,000 on it
DRyanC
shouldn't plugs be good for at elast 50k?
125whp/129wtq
352whp/360wtq Dynojet
13.3@106mph
2004 Ford F-150 Lariat
2013 China 90cc dirt bike
plug wires instead?
loose/bad ground?
DPFE?
What plugs are you running?
Ryan and the Silver Sedan
[Image: 49951.png]
Well I started with the plug, I'll see if I get a call from the wife today. I had Bosch platinum in it. I know they were replace once when the car was under the 3/60,000, then I changed them maybe 3, maybe 4 years ago, but that's only 30-40,000km. I thought platinum plug are like 100,000, no?
Another question, Focushacks has 49ft/# for the rear spindle nut for the drum, is this correct? (if anyone catches this)
DRyanC
I know Foci don't like the Bosch Platinum stuff. If you're going to replace, use stock Motorcraft ones from Ford, unless you are boosted.
49 ft/lb for the nut that holds the drum onto the spindle? I thought it was way more than that (like over 180 ft/lbs).
[Image: 49951.png]
that's what I thought. I know I didn't loosen a nut that was tightened that much, it was pretty much 2 fingers on a bar to loosen. I did put them on tighter than they came off but not 180.
DRyanC
DRyanC,Dec 9 2009, 11:18 AM Wrote:that's what I thought. I know I didn't loosen a nut that was tightened that much, it was pretty much 2 fingers on a bar to loosen. I did put them on tighter than they came off but not 180.
DRyanC
[right][snapback]298280[/snapback][/right]
A quick google search says 173 lb/ft. http://www.justanswer.com/questions/1rlxv-...ear-spindle-nut
[Image: 49951.png]
Well, one I know the dealer had off for service, the other hasn't been removed since assembled on the line.
DRyanC
  Trouble Starting DRyanC 7 2,937 12-08-2009, 07:37 AM
Last Post: Feral
