Threads: 36
0
I am having a huge problem with my Focus. I have a yellow light with an explanation mark come on. When it comes on, I lose power and the engine "bogs" or"putters. I ran the computer on it and no codes come up, all sensors are good. Anyone know what the light means? it is the yellow one just below the airbag light.
Threads: 173
IIRC that is the check engine light and if you're not getting a code when the engine is running normally, its an intermittent failure of some kind which is a bugger to trace yourself unless you have a code reader that can log data from the engine computer while the car is in motion...
Threads: 41
4
Multi-function: Automatic transaxle/cooling system - (On Zetec or automatic transaxle vehicles only) -- Check your coolant level and your tranny fluid. If it lights while driving, bring your vehicle in for service.
It's in your manual.
Threads: 36
0
its a 5 speed...Is there a way to check the tranny fluid on the 5 speed? I cant find anywhere to check the level
Threads: 833
it's the {!} light right?
I had if go off in my car a few times, it's a warning for the cooling system, it's a safety feature to prevent your focus from over heating on you. Call you dealer to set up an appointment pronto.
Threads: 54
I've had that light come on and the car sputter before b/c of a loose connection on the battery cables to the battery terminal. Check that out make sure they're tight.
Current
09 F150 SCREW 4X4 XTR
Former
Show
Go
Threads: 36
0
Yup, just did all the wiring.....everything is tight and all brand new.....I am going to go and get the cooling system checked out....Thank you guys
