Threads: 938
0
Replace the belt and tensioner on or cars. I think that might be the reason my car whines and flickers when I use my accesories.
I'm thinking that id the alternator was pooched, it would have gone by now. It's been 4 months since the whining started.
Any ideas fellas?
Threads: 411
I dont know how comfortable you are under the hood...and dont take offence to this....You asked what burned fuses look like...not a good sign :P
Its not hard, when I installed my pulley it took me about 45 minutes to do, that was with a new belt to.
Threads: 938
0
Flofocus,Mar 28 2007, 02:49 PM Wrote:I dont know how comfortable you are under the hood...and dont take offence to this....You asked what burned fuses look like...not a good sign :P
[right][snapback]232306[/snapback][/right]
Like I was going to attempt this on my own.
Pahlease. :lol:
Threads: 411
ANTHONYD,Mar 28 2007, 03:53 PM Wrote:Flofocus,Mar 28 2007, 02:49 PM Wrote:I dont know how comfortable you are under the hood...and dont take offence to this....You asked what burned fuses look like...not a good signÃÂ :P
Pahlease. :lol:
[right][snapback]232309[/snapback][/right]
lol
Threads: 20
0
I think If I goto a meet I am going to burn several copys of my online ford service manual... for every ford 02-03 (most of us) and sell em for a quarter to recoup my CD costs....
Threads: 190
Shouldn't be hard to do, so long as you make sure the cams are aligned properly or you're going to have some bent valves. I learned this the hard way when I bent valves on my escort many years ago.
Should be able to just put a breaker on the tensioner to release the tension, and just slip the belt off.
Team PITA
Threads: 72
Um, I think he was talking about serpentine belt, not timing belt...
Shouldn't take too long. Just have to get the car in the air, remove the shroud on the bottom, unbolt the idler, pull old belt, insert new belt, then bolt up idler.
Right Flo?
Ryan
Ryan and the Silver Sedan
Threads: 49
^^^ Yeah thats right, simple as pie ;)
15.7 @ 86mph
12.3 @ 110mph
1/4 TBD
Threads: 411
torradan,Mar 29 2007, 07:37 AM Wrote:Shouldn't be hard to do, so long as you make sure the cams are aligned properly or you're going to have some bent valves. I learned this the hard way when I bent valves on my escort many years ago.
[right][snapback]232370[/snapback][/right]
your talking about the timing belt.
Threads: 938
0
Matt and I are going to do a little "tune up Anthonies ride" day in a few weeks.
We're going to tackle the following:
Fuel filter
Tranny Fluid
Plugs
Alternator.
I'm planning on doing how-to's and a write up for each.
Threads: 173
ANTHONYD,Apr 3 2007, 07:46 AM Wrote:Matt and I are going to do a little "tune up Anthonies ride" day in a few weeks.
Fuel filter
Tranny Fluid
Plugs
Alternator.
[right][snapback]233006[/snapback][/right]
I'm curious, do the stock Ford plugs even need anything done to them? I thought they came pre-gapped so that they were simply pull old plugs and put in new plugs? :huh:
Hell, I thought that plugs and wires was about the only part of a "tune up" that I could actually do myself because of that :(
Threads: 411
04-04-2007, 02:47 AM
(This post was last modified: 04-04-2007, 02:48 AM by Flofocus.)
Nef, I'm sure they come pre-gapped, but I always check anyways. The gap tool is really cheap, doesnt cost much at all and you can pick them up pretty much anywher, and its very easy to use.
Threads: 9
0
Gap tools themselves, seeing as I've never used one, do you change the gap by putting the little tool in the plug and .. uh .. what then ? I know that's how you check the gap.. but if you need a bigger gap, or smaller.. How do you get it?
Bend it..? Squish it?
Threads: 411
04-04-2007, 07:35 AM
(This post was last modified: 04-04-2007, 07:37 AM by Flofocus.)
ex1z7,Apr 3 2007, 05:26 PM Wrote:Gap tools themselves, seeing as I've never used one, do you change the gap by putting the little tool in the plug and .. uh .. what then ? I know that's how you check the gap.. but if you need a bigger gap, or smaller.. How do you get it?
[right][snapback]233083[/snapback][/right]
I use needle nose pliers and carefully adjust with those. Check with the tool and adjust agin if required.
Threads: 98
0
I dont think your whine would be the pully.
But you never know till you get it off and have a look at the bearing.
But just as a point of ref. Dont by the new good year Gator back belt... it whines to. <_<
Its just cause of the design
2000 ZX3
