Iac Motor
Where is the IAC motor on the Zetec.
Im getting a slight sputter after I drive for a while and stop. it only happenes once in a while leading me to the conclusion that it needs to be cleaned.
Never done it before so if some one has a pic or a discription it would help.
2000 ZX3
talkin about the idle air control sensor?
hardk0re,Jan 25 2007, 10:46 AM Wrote:talkin about the idle air control sensor?
[right][snapback]224503[/snapback][/right]
No. I was told I need to clean the motor by ford.
Unless its just a sensor and either way I need to get to it and clean it.
2000 ZX3
The IAC is a sensor. Its located under the Intake manifold between the block and firewall.
So I fixed it. Vacume leak of the EGR. the little plasic hose had a split in it, basicly grabbed another off the floor at my work and its fixed. lol
2000 ZX3
I Get a Little Popping Spudder sound from the Rear of the Motor.
Chromey,Jan 28 2007, 10:32 PM Wrote:I Get a Little Popping Spudder sound from the Rear of the Motor.
[right][snapback]224932[/snapback][/right]
thats zetec kicking in.
Wow that car is a hunk of junk.
You're spending more time fixing it than driving it.
ANTHONYD,Jan 30 2007, 09:15 AM Wrote:Wow that car is a hunk of junk.
[right][snapback]224988[/snapback][/right]
Thats what owning a FORD is all about - More fun that way! ;)
Cheers,
ANTHONYD,Jan 30 2007, 10:15 AM Wrote:Wow that car is a hunk of junk.
Wow man you managed to say the same useless thing in like 5 different topics rather then post somthing usfull again.
It actually turned out to be a small vacume leak. Fixed it with a little automotive goop.
2000 ZX3
[right][snapback]225008[/snapback][/right]
I'm just stating the obvious.
You're a star! :rolleyes:
And you're one to talk about usless posts. :lol:
Users browsing this thread: 5 Guest(s)
