Pcv
PCV valve? Do I have to rent a engine lift to replace it?
2000 White ZTS: retired
K&N Filter.....
On a 2.0 its zetec/spi its just behind the exhaust manifold on the front. You'll see black odd looking box and a black hose attached to it which runs around the drivers side of the motor.
The PCV valve is plugged into the box behind the header, tug on the hose attached and you should be able to remove the pcv and replace it.
This is a shot of the PCV valve, my exhaust header is off in this pic.
[Image: DSCF0793.jpg]
if you have a stock header and heat sheild, you will have to go at it from underneath the car, if you have an aftermarket header takes 5 mins :)
'05 Grand Cherokee LTD Hemi
Stock Zetec. Next oil change, I'll replace the thing. Thanks
K&N Filter.....
