Special Service Message 19355
SSM 19355, OASIS Service Codes: 497000, 603300, 608000, 608400, 611000, 611500, 612000
2006-2007 Multiple Vehicles 2.0L/2.3L I-4 Duratec - Driveability Concerns and/or DTC P0340 – Inspect Crankshaft Pulley
Some 2006-2007 Focus, Escape, Fusion and Ranger vehicles equipped with I-4 Duratec engines may exhibit unusual engine noise, crank/no start, hesitates/surges, or rough idle concerns. Diagnostic trouble code (DTC) P0340 may be present in the powertrain control module (PCM) as well. The concern(s) may be caused by the crankshaft pulley. Prior to following normal diagnostics, visually inspect the crankshaft pulley damper for proper alignment or damage without removal. Service as necessary. It is critical that proper service procedures and special service tools are utilized if the pulley needs to be removed for service or severe engine damage may result. Refer to workshop manual section 303-01 for proper service procedures. If the crankshaft pulley is not damaged
continue with normal PC/ED diagnostics.
Where do you get this info?
Does a shorty anntena count as a mod?? Wink
2006 ZX5 UV red with SAP package
"Two things in life are infinite: the universe and human stupidity; and I'm not so sure about the universe"
ZX5chica,Sep 22 2006, 11:39 AM Wrote:Where do you get this info?
[right][snapback]208083[/snapback][/right]
Ford has recently started providing its dealers with a weekly summary of the TSBs and SSMs published the week prior ... and I have my sources ... these might also be available on the internet but I didn't check.
  Special Service Message 19331 ZTWsquared 0 914 09-22-2006, 04:18 PM
Last Post: ZTWsquared
  Special Service Message 19362 ZTWsquared 0 985 09-22-2006, 04:15 PM
  Ford Special Service Message (ssm) 19349 ZTWsquared 0 1,192 09-22-2006, 04:09 PM
