Threads: 17
0
Does anyone know where to get a Focus RS Fuel Pump or a part # of one?
Would you know the pumps capabilities? (Flow rate in LPH or GPM)
Thanks
~ DECEASED ~
The Z-ed Sled ('03 ZTW)
-Eibech Pro Kit
-17" SVT Euro's
-Tip & Tint for show
-nothing for go...yet!
Threads: 13
0
Europe.
Expect to pay LOTS.
White 2001 ZX3
17" FRPP White Rally Wheels, KW Cup Kit (1.6", Progress 22mm Rear Sway, Short Ram Intake w/K&N Cone, Steeda 65mm TB, Ported 2k Manifold, FRPP 9mm Wires, MAC UDP, Clear Markers, OBX 4-1 Shorty Header, OBX ORP, FS Flex, 2nd Gen. MBRP Exhaust, FS/SCT Multi Chip
My Focus
My Photography
Threads: 36
0
RS pump spec 255 lph , tank capacity 55l.
Keep in mind the rs fuel system is return type not returnless like NA spec focus, so you can't just swap the fuel pump . You will need the whole set up .The cheapest way is just get an svt pump it is good for 300+fwhp, if you need more just add boost a pump from kenny bell and you should be good for 350+fwhp B)
Threads: 96
0
just get a walboro pump that is good for atleast 255lph i believe .. you can usually find them pretty cheap then just adapt it to the stock pick-up inside the tank
Below Average Car Club
Threads: 84
0
Walboro pumps are not designed for returnless systems unless they started making them recently...
SVT pump is the way to go...
