2006 Aston Martin V8 Vantage
http://www.canadiandriver.com/articles/l...antage.htm
[Image: vantage_12-1.jpg][Image: vantage_7-1.jpg][Image: vantage_8-1.jpg]
Review and photos by Laurance Yap
The man who runs Aston Martin, Dr. Ulrich Bez, might be described as a bit of a fanatic. He's hop-scotched all over the auto industry, and has held positions at BMW, Porsche, and Daewoo, among other companies. Rumour has it that his house in Germany - he also has a home in England - has a BMW Z1 and Porsche 911 parked in the middle of the living room. Bez, after all, was the man who was largely behind the engineering of both these vehicles.
You can sense, then, that the new V8 Vantage is the car Bez has been waiting to build since he started running Aston a few years ago. The company makes no pretence of suggesting that it's anything but a direct competitor to the 911. In terms of price - its $135,000 Canadian list is just a few thousand more than a Porsche Carrera S, but with more standard equipment and packaging - it's right in the same ballpark. The Vantage is actually a few centimetres shorter than the Porsche, but has a wider stance; its tightly-wrapped body is pulled over a longer wheelbase but it only has two seats.
For roughly the same price as the Porsche, the Aston certainly feels a lot more special. The interior is just magnificent. Aston offers a huge range of colour and trim options, and my tester was done up in a super-tasty combination of black and saddle-coloured leather accented with red stitching. Almost every surface you touch is covered in leather or bamboo or raw aluminum. The gauges are beautifully lit at night and the speedometer and tachometer rotate toward each other as you accelerate (the "Power Beauty and Soul" message you get on startup in the DB9 is gone, however). The console is a waterfall of aluminum with tiny black-on white displays, and the seats - well, they may just be the best-looking seats ever.
Unlike the Porsche, you don't need to pay extra for the leather dash or the excellent stereo (try cranking up the subwoofer when you're in traffic) or power seats with the Aston. But the company's vast range of personalization options - the matching of colours to samples you provide; custom-fitted luggage; or whatever else you please - gives you ample opportunity to inflate the base price.
If the Aston's cabin is sexier than a 911's, it's about equally roomy, but there are parts of it that don't work quite as well as they should. The stereo and navigation controls look great, but they're tiny and hard to use while driving; the navigation system, derived from the one Volvo uses, is reasonably easy to use, but you can't adjust the angle of the screen. The seats are not actually that comfortable over long drives, though they have excellent bolstering for corners. And the controls for the trip computer are scattered between the column stalks and the console. The handbrake is a fly-away type, located between the driver's seat and the door; the seat controls are located on the side of the console.
For sporty driving, though, the Vantage's biggest issue is its sightlines: this is a difficult car to see out of. The roof is low, the windshield is aggressively raked, and the pillars are very thick. Seeing around corners often requires you to crane your neck, there are big blind spots, and the mirrors are tiny. Despite being about the same size, a 911's upright greenhouse and thin pillars make it feel like a significantly smaller car on a winding road, and its peaky fenders make it easier to place the front wheels accurately.
You do, of course, get used to it. And the compensation for the poor sightlines is a simply gorgeous body. Even though my tester was done up in pretty innocuous black, it drew stares like few other cars I've ever driven. Whether it's the clean, taut lines, the simply-executed but beautiful wheels, the neat details like the air vents that form "spines" along each side of the car, the boomerang tail lamps, the side-view mirrors that almost float on metal spars, or the real-aluminum grille, there's just so much more to drink in here than just the shape. Check out the exhaust pipes, flanking a mesh-covered diffuser with integrated reversing sensors; the little eyebrows where the headlamp washers hide; the tiny door handles that spring open with a touch of your finger.
Given all of the stares, it's tough not to be a little self-conscious driving this car. Find a deserted stretch of road away from the adoring public and you discover that the Aston is way more than just a great car to pose in. Its super-stiff aluminum structure has allowed the company's engineers to tune the suspension for excellent cornering grip and stability while maintaining fine ride quality. There's more body roll than you might expect in corners, but once it takes a set, the Vantage feels really stuck in, like nothing's going to make it deviate from its path. Partly, that's because the steering and chassis are so communicative: you really get a sense of what's going on at the road surface, and thus are aware just how much more the car has left to give. Even on wet roads, it's confidence-inspiring and easy to drive fast.
More importantly, it sounds fast. While the Vantage's 4.3-litre V8 is plenty powerful for its weight - 380 horses motivate 1,570 kg - its 302 lb-ft of torque live mostly up high in the rev range, and its six gears are fairly long. The dash from 0-100 km/h takes 5 seconds flat, a few ticks off the Porsche, but the noises coming from the twin tailpipes make the Aston sound easily twice as fast as it is. While the V8 is actually fairly muted while cruising (windows up and in the super-tall sixth gear, this is an easy and comfortable highway mile-eater), even gentle pressure on the gas pedal unleashes an aural assault the likes of which it must be heard to be believed. At full throttle, the Vantage sounds like it has a barely-restrained stock car engine under the hood, and no mufflers at all; it's one of the sexiest noises in the world if you like cars.
Despite some shortcomings - in addition to the ergonomic glitches I've noted above, my tester's electric fuel filler release didn't work and its stability-control system decided not to activate on startup a couple of times - there's no way this car isn't going to be a major success for Aston. It may not be quite as focused a driving tool as a 911, but its newness and rarity are going to be a huge attraction for people who already own a - or have already owned more than one - Porsche or Corvette or Mercedes coupe. Hell, given the reaction it got, the thing will sell on looks alone, never mind the fine dynamics or the standard feature content or hatchback practicality.
There's one other, and very important, thing worth mentioning. Everyone who yelled at me from their passing cars, from bus shelters, or in parking lots with the inevitable "what is it/how fast/how much" was shocked at the car's price. They all figured it would be twice as expensive as it actually is.
"Heck," said one guy at McDonalds. "That's less than my condo cost; what a deal!"
Specifications:
Base price $135,500
Type 2-door, 2-seater sports car
Layout Front engine/rear-wheel-drive
Engine 4.3-litre V8, DOHC, 32 valves
Horsepower 380 @ 7300 rpm
Torque (lb-ft) 302 @ 5000 rpm
Transmission 6-speed manual
Tires front P235/45ZR18 Bridgestone Potenza
Tires rear P275/40ZR18 Bridgestone Potenza
Curb weight 1570 kg (3461 lbs)
Wheelbase 2600 mm (102.4 in.)
Length 4382 mm (172.5 in.)
Width 1866 mm (73.5 in.)
Height 1255 mm (49.4 in.)
Cargo capacity 300 litres (10.6 cu. ft.)
Competitors
* Buyer's Guide: 2006 Porsche 911 Carrera S
* Buyer's Guide: 2006 Chevrolet Corvette
* Buyer's Guide: 2006 BMW 650Ci
Manufacturer's web site
* http://www.astonmartin.com
have you heard the noise it makes.
so drool worthy.
'03 Focus SVT
FocusGuy7476,Jun 9 2006, 07:58 PM Wrote:have you heard the noise it makes.
so drool worthy.
[right][snapback]192428[/snapback][/right]
Unfortunatley no, the only Aston I've seen in person was a DB9.
*drool*
aston...ma....*gaaaaaaaaaaaaaaaaaaaaaaaaa!*
Hey I get a plan on that car. Wonder if the discount is over $20k??? I think the wife might like it. And if she didn't
I would take it off her hands.
meford4u,Jun 12 2006, 09:16 PM Wrote:Hey I get a plan on that car.  Wonder if the discount is over $20k???  I think the wife might like it.  And if she didn't
[right][snapback]192727[/snapback][/right]
Same here, but regardless of our discounts, it's still way out of our league! :lol:
'14 Escape 2.0t
2012 5dr Ti : Traded
Aston Martin = Where It's at....
Bleeding Ford Blue again...
  Thinking about an Aston Martin? ANTHONYD 7 3,929 08-16-2012, 09:32 AM
Last Post: adamzx5
  An Aston Martin For The Rest Of Us 2001 ZTS 6 3,140 07-23-2009, 12:56 AM
Last Post: NOS2Go4Me
  Aston Martin Likely Sold To Prodrive Frost__2001 5 2,051 03-13-2007, 08:05 AM
Last Post: darkpuppet
  For Sale: British Sports Car Maker, Aston Martin Focused 6 2,730 09-23-2006, 04:35 AM
Last Post: mo_focus
  Ford To Explore Strategic Options For Aston Martin Frost__2001 0 989 09-02-2006, 04:38 AM
Last Post: Frost__2001
  Aston Martin At Yonge And Davisville darkpuppet 2 1,859 10-17-2005, 10:55 PM
Last Post: ANTHONYD
