05-24-2006, 02:33 AM
:( :( So, 2 days ago i tried to open my hatch (02 wagon) with the keyfab and nothin. Then i tried with the button on the dash and still nothin. :blink: Is there a fuse for this?? HELP. using the key is soooo 80's.
Can't Open Hatch Without Key
05-24-2006, 02:51 AM
if its not the fuse, try the back of the switch. the plug might of come loose from the back of the trunk release button.
--Henry Ford 00 Focus ZX3 Silver- Sold 01 Focus ZX3 Green- Sold 01 Focus ZTS Red- Sold 03 Focus ZTW Green Sold 04 Escape LTD Silver- Sold 05 Freestyle LTD Black-Sold 02 Honda CRV EX-L-Sold 02 VW Jetta GLS TDI Silver-Sold 11 VW Jetta TDI 6spd Mine ![]() 10 VW Golf Highline DSG- wrote off ![]()
05-24-2006, 03:31 AM
Flofocus,May 23 2006, 10:42 AM Wrote:The doors arent locked when your trying, are they? :unsure:That doesn't matter least not on the 05's it still pops the hatch.
2005 Liquid Grey ZX3 RIP
http://members.cardomain.com/phantom66 Mods so far : Mazda 3 Wiper Arm, Shorty Antenna, Alpine CDA-9887 HU, 17" Enkei Evo6 Hyper Black Nexen N3000 215/45/17 2010 World Rally Blue Subaru Impreza WRX STi
05-24-2006, 03:38 AM
its a wagon...
98 Grand Cherokee 5.9: Flowmaster; K&N 05 300C 5.7: Sold 99 Civic SIR: Sold 03 Focus SVT: Sold 01 Focus ZX3: Sold
05-24-2006, 03:48 AM
Phantom,May 23 2006, 01:31 PM Wrote:Flofocus,May 23 2006, 10:42 AM Wrote:The doors arent locked when your trying, are they? :unsure:That doesn't matter least not on the 05's it still pops the hatch. It does on mine. If the front doors are locked, the trunk release wont open the trunk.
05-24-2006, 04:16 AM
Flo's right, if you try to pop the hatch with the front doors locked it wont work with the button inside the car, but by remote it should work. Maybe the release selenoid is cooked? Or a loose electrical connection? Tear it apart and investigate :) its the only way unless you still have warrenty then take it to the stealership
05-24-2006, 05:06 AM
scoobasteve,May 23 2006, 05:38 PM Wrote:its a wagon... You powers of deduction are incredible! how do you do it captain obvious?! :D
MBRP................ check SCT Xcal2 ........ check VF mounts Adj. Dampers ... check Meford's Mom.... sale pending
05-24-2006, 05:15 AM
Um OK thanks, but where is the DAMN FUSE???? I looked in the cheesy manual and couldn't find anything.
And as an FYI, NO the doors were not locked. and NOPE on the warranty either. So, if it's not the fuse then, would it be safe to assume it's the solenoid? No "clicking" sound when i push either button. and guys, THANKS ! :)
05-24-2006, 05:17 AM
Burnin21,May 23 2006, 11:16 AM Wrote:Flo's right, if you try to pop the hatch with the front doors locked it wont work with the button inside the car, but by remote it should work. Maybe the release selenoid is cooked? Or a loose electrical connection? Tear it apart and investigate :) its the only way unless you still have warrenty then take it to the stealership:huh: DEFINE TEAR IT APPART??? :huh: :blink: :o I'm Scarred.
05-24-2006, 05:23 AM
Are the batteries good in your keyfob?
Also, it may be the contacts on the electronic latch itself. My trunk on my sedan only opens when it feels like it :rolleyes:
05-24-2006, 05:26 AM
nass,May 23 2006, 03:06 PM Wrote:scoobasteve,May 23 2006, 05:38 PM Wrote:its a wagon... I harnessed the powers of Jehova!
05-24-2006, 05:52 AM
back on topic please.
05-24-2006, 06:27 AM
momswgn,May 23 2006, 07:17 PM Wrote:Burnin21,May 23 2006, 11:16 AM Wrote:Flo's right, if you try to pop the hatch with the front doors locked it wont work with the button inside the car, but by remote it should work. Maybe the release selenoid is cooked? Or a loose electrical connection? Tear it apart and investigate :) its the only way unless you still have warrenty then take it to the stealership:huh: DEFINE TEAR IT APPART??? :huh: :blink: :o I'm Scarred. Before you take the whole back apart, just look under the dash switch, as i said most likely it has come off.
05-24-2006, 12:25 PM
mo_focus,May 23 2006, 01:27 PM Wrote:NOPE , it has not come off. Come on guys HELP !!!! :blink:momswgn,May 23 2006, 07:17 PM Wrote:Burnin21,May 23 2006, 11:16 AM Wrote:Flo's right, if you try to pop the hatch with the front doors locked it wont work with the button inside the car, but by remote it should work. Maybe the release selenoid is cooked? Or a loose electrical connection? Tear it apart and investigate :) its the only way unless you still have warrenty then take it to the stealership:huh: DEFINE TEAR IT APPART??? :huh: :blink: :o I'm Scarred. And back to my original question which fuse is it and where is it???
05-24-2006, 01:03 PM
Easy way to check for a burnt fuse. Get a test light and check them all. Probe both sides and watch for the light to go out. On the fuse panel cover it should give you some basic guidelines on which fuse does what. Best way is to get in there and check.
Oh BTW they are under the dash on the drivers side close to the door.
2008 Taurus X to be modded. 2002 ZX5 parted out. Forever known as the "SLOCUS". 2010 Dyno #'s 102.96HP/105.84TQ 2011 Dyno #'s 111.44HP/115.17TQ Still The Weakest Link ![]() Dial 1-800-AUTO-PARTS for your local speed shop.
05-24-2006, 01:40 PM
Ya fuses are located drivers side close to the floor like focus man focus said. As for tear it apart, just take off the hatch interior trim and find the motor/selenoid that unlocks the hatch put your ear up to it and hold the unlock button. Hear anything? Nope, then thats your problem (check fuses first tho PLEASE) If yes then ?!?! I dunno. I bet thats your problem tho, it might have cooked itself or just needs to be cleaned :)
05-25-2006, 07:43 AM
Focus man, Focus.,May 23 2006, 08:03 PM Wrote:Easy way to check for a burnt fuse. Get a test light and check them all. Probe both sides and watch for the light to go out. On the fuse panel cover it should give you some basic guidelines on which fuse does what. Best way is to get in there and check. Thanks, I know where the fuses are but i was hoping someone might know exactly which one i need to be looking at as there are over 40 if i remenber right. i looked in the manual again and there is no mention of "hatch" "pwr door" "rear" anything. :huh: crappy and useless manual.
05-25-2006, 08:45 PM
(This post was last modified: 05-25-2006, 08:46 PM by Focus man. Focus..)
momswgn,May 24 2006, 04:43 PM Wrote:Focus man, Focus.,May 23 2006, 08:03 PM Wrote:Easy way to check for a burnt fuse. Get a test light and check them all. Probe both sides and watch for the light to go out. On the fuse panel cover it should give you some basic guidelines on which fuse does what.  Best way is to get in there and check. Yes this should help you out. If the fuse is ok, take the trim off from around the Speedo and check the connection at the release button on the dash.
2008 Taurus X to be modded. 2002 ZX5 parted out. Forever known as the "SLOCUS". 2010 Dyno #'s 102.96HP/105.84TQ 2011 Dyno #'s 111.44HP/115.17TQ Still The Weakest Link ![]() Dial 1-800-AUTO-PARTS for your local speed shop. |
« Next Oldest | Next Newest »
