Transport Canada Issues Latest Recalls
November 30, 2006
Ottawa, Ontario - Transport Canada has issued its latest recalls, which may affect some Audi, Acura and Nissan vehicles.
2006-2007 Audi A8
Vehicles affected: 234
On certain vehicles, in cases where a weak battery exists, it is possible that a low-voltage condition could cause the airbag control unit to improperly set a fault code. If this occurs, the passenger side frontal airbag will become deactivated, and would not deploy during a frontal crash. Dealers will update the airbag control module software.
2007 Acura RDX
Vehicles affected: 38
On certain vehicles, the dealer-installed accessory trailer hitch was not welded properly during the manufacturing process. Dealers will inspect and, if required, replace the hitch assembly.
2004-2006 Nissan Titan
Vehicles affected: 2,500
On certain King Cab vehicles, wires in the harness routed through the rear doors and into the body may break, due to over-bending of the harness as the door is opened and closed. On the left side, the harness contains wires for the driver's seatbelt pretensioner, and on the right side, wires for the front passenger seatbelt pretensioner and seatbelt tension sensor. Wires for the rear audio speakers are also contained in each harness. If the wires for the seatbelt pretensioner and the speaker break and make contact, there is a possibility the pretensioner may deploy; if this happens when the seatbelt is retracted, it will not be possible to use the seatbelt. If one of the seatbelt tension sensor wires breaks, the passenger side front airbag will not deploy in a frontal crash. Dealers will inspect and, if necessary, replace the wiring harness with an updated version.
Very Interesting.
THis is the problem I had with my Jetta. Low Battery was setting off the Airbag light.
2006-2007 Audi A8
  Transport Canada issues latest recalls Frost__2001 1 2,247 09-29-2010, 01:52 PM
Last Post: reldridge
  Transport Canada announces latest recalls Frost__2001 1 2,412 08-19-2010, 02:34 PM
Last Post: Spinal
  Transport Canada issues latest recalls Frost__2001 2 2,480 07-17-2010, 12:02 AM
Last Post: NefCanuck
Information Transport Canada issues latest recalls Frost__2001 7 4,399 06-12-2010, 04:01 AM
Last Post: Mystake
  Transport Canada issues latest recalls Frost__2001 3 2,567 05-06-2010, 11:12 AM
Last Post: mo_focus
  Transport Canada Issues Latest Recalls Frost__2001 1 2,294 04-20-2010, 11:36 AM
  Transport Canada Issues Latest Recalls Frost__2001 7 3,835 03-31-2010, 01:37 AM
Last Post: Mystake
  Transport Canada Announces Latest Recalls Frost__2001 4 3,082 02-25-2010, 11:31 PM
Last Post: Scorcher000
  Transport Canada Issues Latest Recalls Frost__2001 0 1,912 02-10-2010, 10:22 PM
Last Post: Frost__2001
  Toyota Recalls 2.3 Million Cars In Canada And U.s. darkpuppet 15 7,552 02-03-2010, 02:53 AM
