Putting Tom Motorsports Seats In The Foci
as it says..i'm looking to put my new set of tom motorsports seats in my car...just curious, what brackets do i need to pick up? if any, and am i gonna have to be creative and fab myself up something?
smith21,Mar 9 2007, 12:25 AM Wrote:as it says..i'm looking to put my new set of tom motorsports seats in my car...just curious, what brackets do i need to pick up? if any, and am i gonna have to be creative and fab myself up something?
[right][snapback]229447[/snapback][/right]
It would probably be way cheaper to get someone to make you the brackets.
2000 Ford Focus Roush Turbo & 2004 Focus sedan
I think the best way is to use the Corbeau brackets that don't come with sliders, get the models with the T at the end I think its 2008T and 2009T. T stands for tall, and these brackets come with sliders.
They aren't a direct bolt up, another member on this site used 1/4" Steel and made a bracket. Basically just mounted the blate to the seat bracket then the seat to that plate.
I used 1/4" high grade aluminum, slightly more but it weighed allot less than the steel.
When I installed my MOMO seats I used the MOMO sliders and mounted them on Sparco bases. All the bolt holes lined up perfectly and the fit was excelent. The only thing I needed to do was put about 4 washers under the front mounting bolts to angle the seats back a little. The MOMO seats I had were a fixed back with no adjustment so I had to shim them to get them the way I wanted. Hope this help with your install and lets see some pic's when your done.
I use Recaro seat base for my Recaro replica which uses the same slider as the Tom's. I need to drill two holes at the base since the crappy sliders is shorter then the real recaro's.
JMS US spec front lip, Rieger R-RX side skirts, Rieger R-RX rear apron, European rear bumper, European tail lights, RPMlabs grill, Painted side mirrors cover, H4 HID kit, Lamin-X yellow fogs, shorty antenna, Loder1899 replica rear spoiler, weathertech window delfector, Injen short ram air box, FC UDP pulley, FC 65mm TB, Focussport race header, Focussport flex, magnaflow hi-flow cat, MBRP catback, SCT Xcal2, ford racing spark plug wire, Tein S-tech, FK Damper kit, Eibach rear camber kit, Focussport strut bar, Painted valve cover, TeamDynamic pro race 1.2 17", Kumho SPT 205/45/17, Hawk HP, brembo blank rotors, Russell SS brakelines, Motul dot 5.1, Recaro replica seats on Recaro seat base, KKM shift surround, In-dash 7" DVD player, Tein Damper-chi doll!!
yea, i have the sliders that came with the seats..gonna do some more homework after ur help
  St Foci Seats KillaCamST 5 2,282 12-16-2008, 12:28 PM
Last Post: Focus man. Focus.
