Battery Light
K, today my battery light came on......I checked the battery, altenator, starter, everything was good. I also checked for bad wires and fuses....again, evrthing is goo.....anybody got any ideas??
redZX3,Mar 28 2007, 12:51 AM Wrote:K, today my battery light came on......I checked the battery, altenator, starter, everything was good. I also checked for bad wires and fuses....again, evrthing is goo.....anybody got any ideas??
[right][snapback]232215[/snapback][/right]
When u say checked... did u actually load test the battery? or test your charging system?
O3 ZX3: Drl-to-drf Mod, Racing mirrors, Shorty antenna, B&M short shifter, Focus Sport 4-1 race header, Focus Sport front strut stabilizer, MBRP cat back, RaceCraft springs, Eibach Pro dampners and struts, RaceCraft 25mm rear stabilizer, Hella lights, Core Racing 17"s.
VF Supercharger Kit (Stage 2)
"I usually don't do this type of work." "I thought you were a professional driver?" "A different kind of driving.".
Best case: You have a loose connection. Tighten everything up, especially the battery
Worst Case: A new Alternator is needed.
2000 White ZTS: retired
2012 Frosted Glass SEL: active
K&N Filter.....
Ya i had this happen to me, turned out to be a loose terminal connection on the battery.
Current
09 F150 SCREW 4X4 XTR
Former
Show
Hella Magic Module Tail Lights, 17" Ford Racing EAP rims, 5% Rear, 20% Front Tint, Panasonic CQ7401 Deck, 2 MB Quart 10's, Alpine Components, Phoenix Gold 500.1 Amp
Go
Steeda Cold Ram Air Intake MBRP Exhaust (Gen 2), FK Coilovers, Hedman Header (Install Pending),FC Hi-Flo Cat (Install Pending),EBC Greenstuff Pads
I load tested the battery, which is brand new it was okay. I am going to clean the battery posts and make sure that isnt the problem.....even though they did look pretty good tonight when I took them off
redZX3,Mar 27 2007, 11:50 PM Wrote:I load tested the battery, which is brand new it was okay. I am going to clean the battery posts and make sure that isnt the problem.....even though they did look pretty good tonight when I took them off
[right][snapback]232242[/snapback][/right]
Have the alternator tested. Aswell make sure the ground for your battery has a clean contact.
And you dont need the alternator pulled out to do it. Have a midtronics test run on it. My work does it for free if you consider it.
2000 ZX3
  Battery Light FocusGuy7476 10 4,708 08-14-2012, 02:46 PM
Last Post: FocusGuy7476
  Battery Light at high speeds 2000zx3sct 3 2,321 07-02-2012, 02:25 PM
Last Post: ZTWsquared
  Battery light arpaul15 5 3,243 08-10-2011, 06:20 AM
Last Post: Riitm
  Battery Light Stays On SVTZX503 16 4,484 02-06-2005, 11:30 PM
Last Post: ThraxXx
