Flashing And Dimming Ebrake Light
i have manual tranny and was wondering if anyone knew what the problem is if i have a spastic ebrake light its not a constant flash... anyone kno it tends to stop after about 80km/h or after bout 10 mins of driving...
girard.k,Apr 3 2007, 09:14 PM Wrote:i have manual tranny and was wondering if anyone knew what the problem is if i have a spastic ebrake light its not a constant flash... anyone kno it tends to stop after about 80km/h or after bout 10 mins of driving...
[right][snapback]233110[/snapback][/right]
Have your break cables checked. Get your self a brake inspection.
Check your brake fluid. I had the same problem with the light flashing and then going off, then staying on. Turns out the clutch master cylinder went and it was drawing fluid from the brake reservoir and leaking it inside the cabin. Check the toe of your floor mats for brake fluid, mine had a spot on it.
It was covered under extended warranty for my car so I only had to pay the deductible. The brake light on the dash will come on when the fluid is low.
guilty,Apr 3 2007, 08:54 PM Wrote:Check your brake fluid.  I had the same problem with the light flashing and then going off, then staying on.  Turns out the clutch master cylinder went and it was drawing fluid from the brake reservoir and leaking it inside the cabin.  Check the toe of your floor mats for brake fluid, mine had a spot on it.
[right][snapback]233118[/snapback][/right]
That makes a tonne of sense ill check it out!!
I had a bad wheel cylinder... and th fludi would get low wnough to trigger the sensor when I cornerd or used the clutch .... just another angle in case the aformentioned don't pan out
good luck
AL
[Image: forumsig.jpg]
ZED_not_zee,Apr 4 2007, 11:51 PM Wrote:I had a bad wheel cylinder... and th fludi would get low wnough to trigger the sensor when I cornerd or used the clutch .... just another angle in case the aformentioned don't pan out
good luck
AL
[right][snapback]233308[/snapback][/right]
what do you mean by wheel cylinder?
Wheel cylinder means wheel cylinder....
that happened to me once, good old ford wheel cylinder
good luck
AL
[right][snapback]233504[/snapback][/right]
uh the wheel cylinder is the cylinder with a piston that pushe's out of bothe sides in between the shoes on your rear breaks to engage them
(if you have drums that is)
  A/C Light Flashing muttsnutts 4 2,755 08-15-2012, 01:06 PM
Last Post: ZTWsquared
  Ebrake Light Chromey 7 2,985 07-12-2012, 11:18 PM
Last Post: sonic_mikey
  Flashing Check Engine Light Frost__2001 6 3,296 08-18-2006, 05:16 AM
Last Post: Frost__2001
