How To Take The Injector Bar(with All 4 Injectors)
can anybody tell me what i have to do to take out that bar with all 4 injectors in it?
thanks
http://www.fordcds.com
download it.
burn it.
install it.
use it.
aaah i just need a quick answer
Unbolt the fuel rail from the intake. Disconnect fuel lines using a disconnect tool (watch out for fuel spray). disconnect fuel pressure sensor. Lift off fuel rail, might be a little sticky. It is only pressed over O-rings on the injectors. Injectors may or may not come out with rail. They are also just pressed in the intake.
If you don't know how to do this then maybe you should get someone who does know to do it for you.
Prolly Is not a word
i had to use a flat head screw driver and pry HARD to get mine out. i lubed the Orings up and it slid right back in.
hey guys i ended up getting it out....now i have a problem with the harness
NikiterZTS,Apr 28 2007, 11:19 AM Wrote:hey guys i ended up getting it out....now i have a problem with the harness
[right][snapback]236625[/snapback][/right]
...and this problem would be...?
'14 Escape 2.0t
2012 5dr Ti : Traded
i took the harness out first. made removal super easy man.
