3000w Power Inverter
Used Condition, Works 100%
Lowest ill go is 200$
Now 150$
Now 120$$ Plus shipping.
http://www.4lots.com/index.asp?PageA...PROD&ProdID=31
Specifications
Inverters: Portawattz 3000 Specifications
Model: Portawattz 3000
Electrical Specifications
Maximum continuous Power 2500W
Surge capability 5000W / 3000W
No load current draw <0.6a
Peak efficiency 90%
Output waveform modified sine wave
Output frequency 60Hz quartz crystal controlled
Output voltage 115VAC RMS +/- 5%
Input voltage range 10 to 15 VDC
Mechanical Specifications
Operating temperature range 0C to 40C
Internal Fuse not user replaceable
Weight 20 lb / 9 Kg
Dimensions / L X W X H 18.5" X 8.0" X 6.25" / 47cm X 23cm X 15.9cm
AC receptacles 2 grounded outlets with dedicated 15A breakers.
Oooh... this would be perfect for the cabin. We're running 12V deep cycles - sure would be nice to have AC...
Steve
1999 ZX2| MX3 H&Rs | S/R Tokicos | 21mm RSB | ES Bushings | HotShot CAI | Knocker mod | MSD Coil & 8.5mm Wires | SCT | B&M SS | SpeedHut Gauges | 16" BSA 303s
Coming soon: FR UDP | Pacesetter Shorty Header
Less is more... "Simplify and add lightness"
Click Here to E-mail Me!
Click here for my eBay auctions
lowblackdub,Feb 8 2008, 10:45 PM Wrote:Oooh... this would be perfect for the cabin.  We're running 12V deep cycles - sure would be nice to have AC...
[right][snapback]257698[/snapback][/right]
make the dream come alive...
bump
bump
