Swapping Throttle Bodies
so I took off my FC 65mm TB today....and installed my stock one.....
fired her up and the car runs like sh!t for a min and the shuts off.........it sounds like its running on 2 cylinders....thats how rough it is......
now i disconected the battery, tried different position TPS.....same thing
wtf?
could i just screw up the TPS by swapping them out? if i did....how much are TPS's?
i need this car running for monday morning :o
help
that same happened to me when i was low on ca$h..
you could try tps but i decided to keep fc tb..
not sure about dealer price but in us, they were about $40 range..
i thought computer would have learned......but im not sure what happened....tomorrow im going to try install FC throttle body back and see if that helps.....but i really need my stock one to be on......
Nick, did you reset the ecu ? I think that you need to clear the ecu since it has now adjusted its fuel maps and idle for running with a larger throttle body I would leave the battery disconnected overnight and such and try going for a drive the next morning with the ecu reset .... Im sure you've already done that though ...
Tps's can be screwed up just by touching them funny ... very finnicky stuff ....
Nick, reset your ECU by disconnecting the battery for an hour or so first. A TPS is $75.00 for a manual transmission, $400.00 for an automatic.
i left it off for 15 min or 20 min
will try longer
but this is balls....i need to go to work in the morning
it sounds like its running on 2 cylinders for a min and then shuts off....... :o
hey nik... you don't have to wait that long... just disconnet the battery and keep on stepping (press, release, press, release....) on the brake paddle ... around 5 to 10 times... this will reset your ecu.
as for the tps, did you install it upside down??
ok well i had to put 65tb back on...and it became normal again......damn this car doesn't wanna accept my stock TB....
no i installed it "normal way"
It's telling you it likes what you've done to it, so don't change it...... :lol:
lol yea but i need to sell it still.....looks like i have to wait till the summer.....i do have sell my ported intake manifold as well
Doubt it has anythign to do with the ecu. Sounds like you have some sort of vacum leak to be honest with you...
could be......the other day i also found exhaust leak.....thats just perfect,,,,leak here and there...
  Throttle Bodies... Spinal 6 2,078 10-25-2007, 10:33 PM
Last Post: Flofocus
