Best Underdrive Pulley Kit?
There is a lot of them, so what is better ?
AEM
FORD RACING
FOCUSSPORT
FOCUS CENTRAL
If you have anyway information... :D
If it doesn't include a crank pulley its garbage
ie: AEM
Run your car, not your mouth
Focus Central 2 piece (even 3 piece if you can find one) is generally accepted as the standard, however people have reported the Ford Racing/Esslinger pulley to be good as well. Personally, I have the FC set waiting for a nice warm day in April to go in.
before focus central came out their 2piece/3piece pulley kit... the best udp (crank pulley) was said to be the AF/X one.. (most HP gain)
but now i assume is the focus central setup (correct me if i'm wrong)
2001 Yellow Focus ZX3
Focus Central..
yeloZX3,Jan 24 2005, 02:43 AM Wrote:before focus central came out their 2piece/3piece pulley kit... the best udp (crank pulley) was said to be the AF/X one.. (most HP gain)
[right][snapback]80430[/snapback][/right]
Very very much agreed. I've also heard of people having problems with the FC 2 piece with their A/C in summer, overheating the car.
I had the AFX on for 8 months now without any charging or cooling issues. I had a bunch of mods done all at once so can't say how much the UDP alone contributed but it is much better than before.
2001 ZTS,Jan 24 2005, 11:09 AM Wrote:I had the AFX on for 8 months now without any charging or cooling issues. I had a bunch of mods done all at once so can't say how much the UDP alone contributed but it is much better than before.
[right][snapback]80468[/snapback][/right]
I have the AFx. Great little mod.
Overheating the car : the engine is too hot or the A/C is throwing hot air inside ???
(usually I speak french :D)
If I don't have A/C, it won't change anything for me ...
zx3demon,Jan 24 2005, 03:52 PM Wrote:Overheating the car : the engine is too hot or the A/C is throwing hot air inside ???
[right][snapback]80481[/snapback][/right]
Its an underdrive pulley, it makes the water pump, alternator and a/c compressor turn less than normal.
I have the FC one for 2-3yrs now, still having the same battery. I will say just get whatever brand you like, they're almost the same.
260000km and counting.....
  • AFX here!<>
    [st]
    Peace...
[Image: Copy2ofKarlitosig.jpg]
I have a 2 peice Focus Central and I am actually taking them off and putting the stock ones back on. There was a big diff.
I never use my A/C anyway though. Even on +40 days. I miss heat :(. The fealing of touching a super hot shift knob. So hot in the car your back sticks to the seat. AHHHHHHHHHHHHHHH come back summer!!!!!!!!!!!!!!!!!
I have the Focus Central 2 pcs and found no problem with it during the summer. :)
I'm also a pre FC guy with a AFX setup.
Ford Racing.
  Underdrive Pulley Kelowna_Focus 17 3,970 01-03-2007, 06:09 PM
Last Post: Burnin21
