  • 2 Vote(s) - 3.5 Average
Rpms Jumping All Weird.
Ford sells a pigtail kit for this connector, and the new part has beefier protection around the wires.
Ended up being low Coolant causing the engine light to go on and I think cause the rpms to jump cause the reserve coolant was completely depleted aswell Undecided
I think the Rpm problem is fixed now that I topped off the Coolant, but i'm getting a bit of vibration still and the coolant leak isn't patched up yet so I gotta figure out how to seal the leak.
(05-08-2010, 01:08 PM)Focus-SE Wrote: Ended up being low Coolant causing the engine light to go on and I think cause the rpms to jump cause the reserve coolant was completely depleted aswell Undecided
Yup, Glad to be of help. My second guess was the coolant. You may have either a small leak or its burning it somewhere?? did you check?
The leak is coming out of one of pipes connected to the manifold I think and sitting between the passenger and the drivers seat underneath. So would it possibly be a Manifold Gasket that's gone bad?
