coilovers
i drive a 07 zx5 and i just have a request to see pics of coilovers that have put into the back. jjust gotta check something to make sure before i install mine.
rear end of 07's same as rear end of 02 svt's?
all rear ends suspension is the same and front is almost the same
what pics/angles do you need?
just a pic of the setup whether it be with the wheel off or a view from behind the focus whatever you have. thanks
all the coilover is, is a springs with a adjuster sleeve in rear perch and a shock external unless you went with focus central rear coilover set up. the front will be a true coilover where coil is over the strut with an adjuster for height
i got custom coilovers from selex and im just wondering how coilovers look in the back
