Bad Idle
My car is idling really bad lately. Bouncing up and down from 500rpm to 1500rpm.
My engine mods are Cold Air Intake (Injen), Shorty Header, 2.5 Dual exhaust (except flex pipe), and Diablo chip.
Never had this problem in the summer. Could it have anything to do with the cold winter air?
If so, can someone explain to me why it's idling like that?
Hedman Header
Hi/Flo Cat
Diablo Chip (re-programmed)
Wings West BodyKit
FK Automotive Suspension
Front and Rear Camber Kit
Fuzion ZRi Summer Tires
Speedhut Indiglo Dash
JVC Head Unit
12 Disc CD Changer
Bazooka Base Tube
Injen Cold Air Intake
What year is your focus? Have you had all the recalls done?
can you explain its behaviour more, as in does it lower slowly then almost stall then shoot up to 15rpm etc...?? and does it only fluctuate at idle?
2004 SVT 3Dr
STKVSTDA
BrooksZX3,Mar 1 2005, 07:42 PM Wrote:can you explain its behaviour more, as in does it lower slowly then almost stall then shoot up to 15rpm etc...??  and does it only fluctuate at idle?
[right][snapback]90524[/snapback][/right]
Yes....it almost seems like it is going to stall then shoots up....or I have to rev the gas to bring it back up to normal. And when it seems like it is going to stall the lights dim?!
Btw it's a 2004 model. I had a 2001 before and didn't experience this problem?
Any suggestions?
Hedman Header
Hi/Flo Cat
Wings West BodyKit
JVC Head Unit
12 Disc CD Changer
Bazooka Base Tube
Your still running the stock TB right?
S2,Mar 1 2005, 08:42 PM Wrote:Your still running the stock TB right?
[right][snapback]90536[/snapback][/right]
Yep, Throtle Body still stock. All the engine mods I have, are listed. Pretty simple setup.
OH YEAH! I got an automatic car starter too. My car is manual. You think they could have messed it up?
RECALLS!!!!??? What recalls are there?
Hedman Header
Hi/Flo Cat
Wings West BodyKit
JVC Head Unit
12 Disc CD Changer
Bazooka Base Tube
[right][snapback]90543[/snapback][/right]
TSB Number Issue Date TSB Title
04-8-1 MAY 04 M/T - Rattling Noise at Idle With Clutch Pedal Released
04-6-1 APR 04 Suspension - Creak, Crunch, Grinding or Rattle Noise
04-5-5 MAR 04 Lighting - Turn Signal Lamps Won't Self-Cancel
04-5-8 MAR 03 Interior - Carpet Pulling Away From Kick Panel
Yeah so none of those. Assuming you got the EGR disable with your DIABLO right?
Just for fun. Check the plugs.
Prolly not the problem but only takes 2 mins.
I would seriosly pop the hood while its running and see if you hear or see anything unusual going on in the engine bay.
Those are not recalls s2 posted. There TSB.
ZX3TUNR,Mar 1 2005, 06:07 PM Wrote:Just for fun. Check the plugs.
[right][snapback]90596[/snapback][/right]
My bad, sorry... called them the wrong thing. Funny cause I knew that actually.... :P
does ford even do tsb for free? or do you have to pay for those?
I would say your cold air intake(water in the intake) is the problem, most of the aftermarket cold air intake position the filter to low. First check if your filter is dry,and I would switch back to the stock air box for the winter. B)
my car does the same thing and allI have for engine mod is a K&N cone filter.
also my brake light come up when I accelerate hard and when I brake hard... :unsure: Have no idea why the hell, and also my batterie light comes up when I come to a stop....
freaking POS but I still love it... :lol:
-1991 Nissan Pulsar GTI-R
-2000 silver ZX3 - sold
yea maybe the plugs, or may also be the plug wires started to fail.
2001 Yellow Focus ZX3
Sounds loud the exact same thing I had one time.
Im not sure how but one day when I was messing around under the hood I some how managed to pop off a plug wire just a tad. LOL Worth double checking for sure.
coolsvt,Mar 2 2005, 01:44 AM Wrote:I would say your cold air intake(water in the intake) is the problem, most of the aftermarket cold air intake position the filter to low. First check if your filter is dry,and I would switch back to the stock air box for the winter. B)
[right][snapback]90657[/snapback][/right]
My cold air intake is an INjen one, so mine doesn't "go low", it sits "up high".
http://www.pbase.com/rmercado_august2004/image/32919484
My car is fairly new with only 20k on it, so this is weird.
Maybe it will cure itself in the summer. I'll check the plug then when it is warmer.
Thanks guys.
Hedman Header
Hi/Flo Cat
Wings West BodyKit
JVC Head Unit
12 Disc CD Changer
Bazooka Base Tube
Check you MAF connection. make sure its really screwed well into the intake tube. Any little crack will throw off your Meter.
ZX3TUNR,Mar 1 2005, 07:07 PM Wrote:does ford even do tsb for free? or do you have to pay for those?
[right][snapback]90637[/snapback][/right]
Depends but from what I know, it's an extension on the warranty if you still have it. I had a couple things fixed under warranty that were deemed TSB's and no cost to me.
Like the other guys have mentioned, its more than likely one of the following:
- bad gas, maybe some condensation in your tank
- dirty or leaking MAFS
- spark plugs
- spark plug wires
Natasha, I would lean towards moisture or water in your intake. I've got a K&N filter on the stock intake. On a particularily damp highway drive, my car suffered similar symptons.
01-yellow-ZX3,Mar 2 2005 Wrote:Like the other guys have mentioned, its more than likely one of the following:
- spark plugs
- spark plug wires
[right][snapback]90759[/snapback][/right]
word
Im only at 21,000 and the car has been sitting for 4 motnhs. LOL
Was your car parked?
