08-25-2012, 12:43 PM
So its time to get some new motor mounts , the stock ones just couldnt take it anymore :p. Which is the best way to go? ( do them all) and what brand?
Motor mounts
08-26-2012, 12:07 AM
depends what you want. Are you looking for a performance aftermarket or a OEM replacement? Unless you are seriously in need of vibrations, i would only suggest doing the rear mount with a poly aftermarket mount. You can do the other 2 aswell, but it will be stiff all together.
As for aftermarket mounts, i use the ones FSWerks sells VF engineering.
FSwerks stage 2 Turbo kit, Cosworth Intake Manifold, 3" custom HKS turbo back regular stage 2 @10ps : 232whp/219wtq stage 2 plus @ 13psi: 278whp/229wtq Stage 2 plus @15psi: 296whp/240wtq 2013 Focus ST Tuxedo Black - The daily
08-26-2012, 04:06 AM
Well I was going to do the passenger side because its the broken one , and since im already in there i might as well replace the other ones. Can you notice a differnce with the stiffer rear mount?
08-26-2012, 04:13 AM
big difference because it is the torque mount that stops the motor from moving when you jam on the gas to shift gears. You wont get that clunk then you powershift into second either
08-26-2012, 02:16 PM
i have all aftermarket 3 motor mounts and girls love my car.
![]() info@motormaniac.ca | 905.508.3737 If you are calling after hours, please leave a pm or detailed voice mail and we will get back to you as soon as possible.
08-26-2012, 04:34 PM
Motor Mounts | shadowzx3 | 21 | 10,832 |
09-18-2009, 12:31 AM Last Post: Spinal |
Motor Mounts | Canadian ST | 18 | 5,270 |
04-29-2007, 03:59 AM Last Post: 02_svt_guy |
