08-27-2012, 07:44 AM
Does anybody know what the small bar is that comes from the front shock assy to the bar Its located about half way down the shock assy and is it available seperately
Front Suspension Question
08-27-2012, 07:51 AM
sway bar end link
info@motormaniac.ca | 905.508.3737 If you are calling after hours, please leave a pm or detailed voice mail and we will get back to you as soon as possible.
08-27-2012, 08:27 AM
(This post was last modified: 08-27-2012, 09:09 AM by muttsnutts.)
08-27-2012, 11:02 AM
Any parts place will have them, I think partsource sells the moog regreasable ones.
08-28-2012, 10:17 AM
08-28-2012, 09:02 PM
Carquest or Napa have them also.
08-29-2012, 02:48 AM
massive makes really really good ones now. The quality is great.
08-29-2012, 09:47 AM
(This post was last modified: 08-31-2012, 02:22 PM by muttsnutts.)
08-31-2012, 11:37 AM
You can drive without them, but it will wander a little, a body roll will go up.
If you've removed one and need to drive, remove both sides, so as not to upset the handling balance.
08-31-2012, 12:06 PM
I drove my 05 around for a few weeks trying to find the clunk on the passenger side until I looked at the drivers end-link and it wasn't attached.
08-31-2012, 02:25 PM
(08-31-2012, 11:37 AM)reldridge Wrote: You can drive without them, but it will wander a little, a body roll will go up.Im in no hurry to drive it I have enough cars lol Just wondering ,Its for the wife for winter .Im going to try and get a pair this weekend but now have another problem getting the bolt undone , Sprayed it with easy off but wont budgeAre they hard to cut off Sorry for all the questions im more of an electrical person
08-31-2012, 03:00 PM
have you tried long breaker bar??
if not, angle grinder is only option. BLACKBOX(DASHCAM) | LED | HID | REMOTE STARTER + SECURITY | 12 VOLT ACCESSORIES | CAR ENTERTAINMENT | PERFORMANCE UPGRADE | MAINTENANCE REPAIR
08-31-2012, 03:11 PM
08-31-2012, 09:34 PM
Yep, cut it off.
Are they the stock ones still on it? If so, it's an Allen key on the stud to hold it, and a box end on the nut. I'd go to the Moog ones. That's what most people run. Better bushing, and greasable.
09-04-2012, 04:54 AM
(This post was last modified: 09-04-2012, 08:08 AM by muttsnutts.)
(08-31-2012, 09:34 PM)reldridge Wrote: Yep, cut it off.I managed to get the Moog ones and with some heat and more easy off managed to get the old ones off. Now I have another problem very weird when the car is cold it sounds like the exhaust system is banging against the body or maybe some mount is no good , It will stay like that until the engine is warm ,then turn it off leave it for 10 minutes or so then the noise/vibration goes away very weird Maybe rear engine mount?
09-05-2012, 04:09 AM
Look at the 'hanger' under the oil pan, that the flex pipe meets the cat pipe at. It's probably rusted through.
09-05-2012, 09:39 AM
09-05-2012, 11:19 PM
Almost the same place, so you can check both!
09-06-2012, 09:34 AM
09-09-2012, 11:03 AM
So checked it out no rust Replaced the rear mount took 20 minutes I was suprised anyways no more vibration. Do you think I should change the top ones too? Domt really want to spend to much on this one its for the wife for winter. Just need to change rotors nowmand thats it.
Suspension question. | Focus man. Focus. | 13 | 4,935 |
05-13-2011, 09:03 AM Last Post: GFXjamie |
suspension question | blue_light | 6 | 3,789 |
02-12-2011, 10:44 AM Last Post: ZTWsquared |
Suspension Question | Chromey | 4 | 2,635 |
06-09-2010, 03:38 AM Last Post: Chromey |
Svt Suspension Question......help | imncrxtc | 29 | 10,343 |
12-08-2009, 08:25 AM Last Post: NikiterZTS |
Funny Clunk From Front Suspension? | NOS2Go4Me | 13 | 3,509 |
05-30-2006, 04:05 AM Last Post: ANTHONYD |
Front D/s Suspension Is Toast | ZX5focused | 11 | 2,952 |
12-10-2005, 05:52 AM Last Post: OAC_Sparky |
So I Turn My Front Suspension/driveshafts | ZX5focused | 10 | 3,362 |
01-25-2005, 08:25 AM Last Post: tdot-zx3 |
Aftermarket Suspension/brakes/ Endlink Question. | darkpuppet | 4 | 2,161 |
01-22-2005, 12:45 AM Last Post: darkpuppet |
