Can some one tell me if the factory head in the 2003 SE has RCA pre outs.
Factory Head In A 2003 Se
11-23-2005, 12:37 PM
no, i don't believe it does..you'd have to pick up a box from a place that works with car audio, they'll know what your talking about. It's around 20$ and you wire it into your speaker wires
11-23-2005, 12:41 PM
smith21,Nov 23 2005, 02:37 AM Wrote:no, i don't believe it does..you'd have to pick up a box from a place that works with car audio, they'll know what your talking about. It's around 20$ and you wire it into your speaker wires
11-23-2005, 12:46 PM
I don't think the base cd player has RCA outs. If you're looking to add an amp to your stock setup, look to get an amp with line-level inputs. That will allow you to use the rear speakers, or front speakers for that matter to provide inputs into the amp.
09 F150 SCREW 4X4 XTR Former Show Hella Magic Module Tail Lights, 17" Ford Racing EAP rims, 5% Rear, 20% Front Tint, Panasonic CQ7401 Deck, 2 MB Quart 10's, Alpine Components, Phoenix Gold 500.1 Amp Go Steeda Cold Ram Air Intake MBRP Exhaust (Gen 2), FK Coilovers, Hedman Header (Install Pending),FC Hi-Flo Cat (Install Pending),EBC Greenstuff Pads
11-23-2005, 09:27 PM
Yeah, none of the factory headunits has them except the sony edition focus. but then that is an aftermarket deck anyhow...
Buy yourself a new aftermarket headunit and scrap the oem s**t
11-25-2005, 02:28 AM
use a Line Level converter instead of an amp with line-inputs, so once you get your sysetm installed and you realize the decks underpowered for your needs, you simply swap in a aftermarket HU and save yourself hours on end without the need to re-wire. PRE-WIRING = GOOD, JUST DO IT IT SAVES EVERYBODY TIME AND FUSTRATION
« Next Oldest | Next Newest »
