Motor Mounts
#21
I just swapped my trans mount last night for the CFM one with race bushing and i love it! Car vibros a bit untill you pass around 1300 rpm in first, but after that its like it not even there. Although you can feel a slight vibration after 3G, but its sooooooo small its almost impossible to notice. Also, if you have the clutch engaged but your off the pedal, you can feel the same thing. All in all, the CFM one is a good buy, the bushings are pretty much solid, but they still need to be worked in
from what i've read it should get a little better once it "breaks in"
  Motor mounts adamzx5 5 3,169 08-26-2012, 04:34 PM
Last Post: adamzx5
  Motor Mounts Canadian ST 18 5,204 04-29-2007, 03:59 AM
Last Post: 02_svt_guy
