Outfitting With Led's
Ok, I am thinking about getting LED bulbs for the interior and exterior. I have read the pervious thread about the Map and Dome lights. So I have some info on what I will need regarding those.
Dome light being p/n: 17314 (Wagner p/n) or a Festoon 3910
Map lights: BP3886LL (Wagner p/n) or in the thread a BA9
If anyone has further info any input is welcome.
Now on to the exterior. I am aware that I should use white or clear lens bulbs in locations with coloured lenses. I know that the required bulbs are as follows:
Front turn signals: 3157
Front sidemarker lamps: 194
Rear stop/turn signal: 3157
Reverse/back-up: 921
Now this is where I need your input. Who has LED's in their car? If so what should I look out for and what are the advantages? Pro's and Con's. Any info or input is greatly appreciated.
Photos would be nice but I know that lights are hard to see in photos. Now its your turn guys. what do you have for me?
GO..........
2008 Taurus X to be modded.
Still The Weakest LinkBlush
Focus man, Focus.,Jan 31 2006, 03:17 AM Wrote:Ok, I am thinking about getting LED bulbs for the interior and exterior.  I have read the pervious thread about the Map and Dome lights. So I have some info on what I will need regarding those.
Map lights: BP3996LL (Wagner p/n) or in the thread a BA9
GO..........
[right][snapback]167635[/snapback][/right]
make sure you pick up some resistors if you don't want the hyper flashing. You can buy electronic flashers at crappy tire but I am not sure they'll work in our car. I need to do something for my led turns I might just end up slaping resistors on them
***want to buy***
MBRP................ check
SCT Xcal2 ........ check
VF mounts
Adj. Dampers ... check
Meford's Mom.... sale pending
What happens? Do they just flash to fast? I would have thought that they would have worked the same way as normal bulbs. I can switch to a HD flasher, no problem. Transport trucks use LED's and they don't have any special wiring. I worked for a HD truck parts company for 2 years and thuy use a normal 2 pin flasher just like cars. Only more robust to handle up to 20 circuts.
Focus man, Focus.,Jan 31 2006, 03:42 AM Wrote:What happens?  Do they just flash to fast?  I would have thought that they would have worked the same way as normal bulbs.  I can switch to a HD flasher, no problem.  Transport trucks use LED's and they don't have any special wiring.  I worked for a HD truck parts company for 2 years and thuy use a normal 2 pin flasher just like cars.  Only more robust to handle up to 20 circuts.
[right][snapback]167639[/snapback][/right]
you need and electronic one not a mechanical one. The problem is that LEDs draw far less current than ordinary bulbs. The car senses that and treats it as a burnt out bulb and lets you know this with a rapid flash. The resistor adds more load fooling the car into thinking that all is normal.
***want to buy***
VF mounts
Because there is not much resistance on the LED the car thinks the light is burnt out and it flashes fast. So you need resistors to draw the same amount of wattage as regular bulbs. This will eliminate the fast flashing.
i think :)
--Henry Ford
00 Focus ZX3 Silver- Sold
01 Focus ZX3 Green- Sold
01 Focus ZTS Red- Sold
03 Focus ZTW Green Sold
04 Escape LTD Silver- Sold
05 Freestyle LTD Black-Sold
02 Honda CRV EX-L-Sold
i think :)
[right][snapback]167641[/snapback][/right]
echo!
***want to buy***
VF mounts
[/quote]
echo!
[right][snapback]167645[/snapback][/right]
[/quote]
haha, i guess you beat me to the bunch line, I kept on getting pulled away while i was trying to type.
--Henry Ford
i have leds in my interior lights and they are much brighter than colored bulbs and you nvr have to worry about fading or the paint cracking off them
E.O MASIV
I've got a LED domelight... and it's actually dimmer than the stock festoon bulb. It's nice and easy on the eyes at night.
I've also got 9 super-bright red LEDs in the trunk which actually look neat.
I can't say I've tried the turn signal replacements yet, but it sounds interesting.
I have front turn signal and rear brake/signal with led... you need to get resister for sure!!! I bought some resister for led turn signal, they hv to hook up in parallel and they work great!! I still have two brand new and two used resister for sell, pm me if you interested. I don't recommad changing the rear unless you can find very bright one, but I am sure is hard to find since not a lot of 3157led out there. For my front I got MS design replica grill so there is no turn signal lense, so i just hook up two amber led behind it and they are bright.
A member took some pic of my front led signal when we hv meet last year.
http://ordocus.fotopic.net/p15835337.html
http://ordocus.fotopic.net/p15835338.html
http://ordocus.fotopic.net/c565514.html
JMS US spec front lip, Rieger R-RX side skirts, Rieger R-RX rear apron, European rear bumper, European tail lights, RPMlabs grill, Painted side mirrors cover, H4 HID kit, Lamin-X yellow fogs, shorty antenna, Loder1899 replica rear spoiler, weathertech window delfector, Injen short ram air box, FC UDP pulley, FC 65mm TB, Focussport race header, Focussport flex, magnaflow hi-flow cat, MBRP catback, SCT Xcal2, ford racing spark plug wire, Tein S-tech, FK Damper kit, Eibach rear camber kit, Focussport strut bar, Painted valve cover, TeamDynamic pro race 1.2 17", Kumho SPT 205/45/17, Hawk HP, brembo blank rotors, Russell SS brakelines, Motul dot 5.1, Recaro replica seats on Recaro seat base, KKM shift surround, In-dash 7" DVD player, Tein Damper-chi doll!!
Autolumination.com has some pretty sweet multi-directional 3157 tail-light replacements, designed to make the most of a reflector-laden environment. At least, that's the way they seem. When I start the LED track lighting conversion project at home in the spring, I'll bring a set over as well to see how they do.
