A/f Gauge Install.
Ok So I hooked up my A/F Gauge today.
Seems to be working, I just understand 1 thing.
Before anyone Says it, Yes Its a NB A/F And Yes its good to have when your running a Chip.
I hooked it up to the Black with yellow Stripe,
My Readings are A little above lean(Not red, All Orange)
But I always get 1 Green flash at Full Rich...
If this is Normal let me know please.
Ok Disconnect from the Black Wire... DIdnt seem right.
Hooked it up to the White wire, Works perfectly.
Dosent jump around like everyone said it would.
:postpics:
Sorry had to be said :P
Current
09 F150 SCREW 4X4 XTR
Former
Show
Go
Chromey,Oct 9 2005, 03:54 PM Wrote:Dosent jump around like everyone said it would.
[right][snapback]147770[/snapback][/right]
Then it snot working properly. unless the guage does something that most guages dont... <_<
At Idle It moves back and forth like the "Night Rider Car"
At WOT Its all Rich, Off gas its Lean.
Seems to work right to me..
Chromey,Oct 9 2005, 11:12 PM Wrote:At Idle It moves  back and forth like the "Night Rider Car"
[right][snapback]147809[/snapback][/right]
whats it doing while cruising?
Same as Idle, Back and Forth.. And a Nice speed .
i was thinking jumping around and going back and forth was the same.
my bad
  How Do You Install Air/fuel Ratio Gauge nvybluzx5 6 5,114 04-27-2004, 05:49 AM
Last Post: bill1459
