De Greasing The Engine
Well I want to degrease the engine in the focus. I did it to the transam and it came out nicely so I was thinking of nailing the focus however I am not sure what to cover up.
In the transam we covered the Throttle Body, Battery, Alt and Distibutor. What all do I need to cover in the focus?
ThraxXx,Aug 25 2005, 10:35 AM Wrote:Well I want to degrease the engine in the focus.  I did it to the transam and it came out nicely so I was thinking of nailing the focus however I am not sure what to cover up.
[right][snapback]135647[/snapback][/right]
When we used to do it at work, I never covered up anything except aftermarket stereo cable, inline fuseholder.. or and exposed airfilter/cai
you might wanna cover the plugs...some might say so!!! apparently you get water and seeds in there!!?!? :rolleyes:
thats about it...The spi is the same s**t....diesels are different and caution should be taken to not fuk them up...
The main thing is, dont sit there and hammer water on one area and makes sure you dry it after so water isnt sitting there....other than that you'll be fine to clean it.. ideally if you have an air compressor...blow all the water out after and i gaurantee you'll have no issues
I always used a tooth brush and simple green takes a while but man does it ever come out clean.
I have a few cars.
One for my dog.
One that has no roof.
One that looks good parked at the golf course.
One that is being rebuilt by a guy named Nero..... will it ever be done?
I warm the engine just a bit to losen up any oils? I cover up the filter and spray the engine down a little with water but don't use high presure. I then coat everything with Simple Green let it soak a bit and spray everything again with water to rinse at a regular garden hose pressure! :D
Silver 05 ZX4 SES
RPM Black 501 18X7, Falken 215/35/18's, MBRP Stainless Cat-Back Exhaust Gen 2, FocusSport Header and Flex, Eibach Sportlines, Eibach Struts & Shocks, Eibach Sway Bars, AEM Cold Intake, FocusSport Strut Bar, Pioneer Head Unit, Boston 6.5 for Doors, Speedhut White Face Gauges, Momo Pedals, Crystal Clear Bumper Lenses, Niken Shorty Antena, Tint. RS Widebody Kit Ready for 2010...!
Fat Guy in Small Car...
Simple Green is the s**t for cleaning Engines... I think I'll do mine this weekend.. it's been a while
Lightly pressure wash it
Dry
Coat in simple green
let stand for 5 mins
get in there with a toothbrush or something similar to get the heavy stuff out
use brush to loosen up the rest
lightly pressure wash the simple green off
Marvel at the beauty that is your engine bay
2000 Black ZX3
hehe, here is how i do it
1- drive up to a coin wash slowly and making sure engine should stay cool
2- let the engine cool down a bit, it should be still warm enough so the oil could loosen up
3- cover nothing :)
4- spray tractor engine cleaner, white can from crappy tire, on the whole engine, cover as much possible, usually i would empty one can per wash, the can cost 4 something
5- let it sit for abut 5 min
6- start the car and then
7- start the pressure washer and wash the engine bay while the car is ON.
once you have cleaned the whole car just drive off. just make sure you drive for about 30 min. this way you are maing sure there will be no water left, engine bay will be so hot that all the excess water will evaporate.
I have been doing this for a very long time and i never had any problems.
I guess i'm just a bit lazzy to use the toothbrush.
I do this once a year. and i think it does a good job.
--Henry Ford
00 Focus ZX3 Silver- Sold
01 Focus ZX3 Green- Sold
01 Focus ZTS Red- Sold
03 Focus ZTW Green Sold
04 Escape LTD Silver- Sold
05 Freestyle LTD Black-Sold
02 Honda CRV EX-L-Sold
Well for my mom's 2001 sunfire GT , I just went to the car wash and opened the hood, and pressure washed the whole thing. worked fine for me. i've been doing that for the past,oooo 3 years, i've never had a problem and it seems to clean fine.
Save points are for quiters
ok thanks for the advice. I will give that a try. BTW Tri_kento, I love your avatar...that is freakin hilarious.
Well, I've sometimes cleaned my engine bay by hand, but other times I've gone to the carwash to do this, but I only put it on "Pre-soak" which is concentrated soap, and then use the spot free rinse which is also low pressure, and that ended up doing a really good job overall...after a nice drive on the highway for about 20Kms, the engine bay was nice and dry and clean....then I went and detailed a few things with spray to make them nice and black and shiney...
Bleeding Ford Blue again...
