WuNgUn's custom machined Getrag shifter bushing...
Picked up a few of the sleeves from the machine shop...more coming. Went with a better quality, shoulder (stripper) bolt, nylock nut and washer...
PM me if you have any questions!
(This is for the large, white shifter bushing on the tranny...)
[Image: dbush.jpg]
[Image: HPIM2113.jpg]
[Image: HPIM2114.jpg]
You basically grind off and drill a 1/4" hole where the linkage stub use to be, and bolt this to the linkage instead.
[Image: piccccs003.jpg]
And of course, you have to gut the worn-out, spongy rubber out of the nylon cable end...
[Image: car2008-2.jpg]
I take it you are selling them? Do you have a solution like this for the side to side slop with the square bushing?
Officially, not selling them....I don't know about the policies on this forum...?
But if you want one, PM me...
For the square bushing, you simple remove it, turn it 90 degrees, and reinstall it...
It's all in the instructions I provide.
I have just 6 left...anyone interested, PM me...
Bump...
Here are the install instructions...
http://www.fileden.com/files/2007/12/23/... rev.3.pdf
Still available...
Here is the bushing mounted to the trans...
[Image: HPIM2116.jpg]
And in the car, with the cable attached...
[Image: HPIM2122.jpg]
  Getrag Fluid sonic_mikey 13 4,915 09-18-2009, 01:07 PM
Last Post: sonic_mikey
