Should I Lube Brake Caliper Bolts?
Is it necessary to lube the front caliper slider bolts? My Focus is only 1year old with 18,000KM
My mazda protege needs this done every 10K or so on the rear, or the calipers risk seizing. So it's preventative maintenance to lube the slider bolts with brake grease.
I do it when I change the brakes obviously, but not when I change the tires. <_<
  Seizing Brake Caliper / Piston? Nutella 9 4,008 04-15-2009, 04:24 AM
Last Post: reldridge
