Poor Idle
need some MORE help people...installed new spi motor, it did run good, at an idle it runs rough. I put pressure on torque converter when i put it in Drive, with foot on the break, its runs even worse (vibration). Now when i stop at a light, sitting in idle when the motor gets hot after driving it for 20 minutes, the battery light comes on and runs real rough, as soon as i touch the accelerator, it runs fine. ALWAYS. at an idle the alternator is charging between 14-15V, but it still runs rough and throws the Battery light on, and it stays on. I think i have a poor idling problem, but dont know where to start, the motor only has 58,000k on it.
If i could get some feedback that would be awsome.
Thanks,
Ian
Loose accessory belt? Idler pulley?
2000 White ZTS: retired
K&N Filter.....
Coil? Sparkplug wires? (unlikely on the second one, but who knows).
Hmmm... fuel filter? Were the injectors fouled at all or did you install new ones?
EDIT - you're charging OVER 14V at IDLE? That's nuts! Check your battery's voltage and see if it's being overcharged. You might blow the sonovagun if you're not careful.
ya, 15.2 I was getting lastnight, i have a tiburon it blew every little bulb in the thing, my alternator was overcharging, could this be the same thing??
how much should i expect from it? 13-14 right? im used to buses chargine sometimes well over 15
could I also have a vacuum leak??
howie321,Aug 23 2007, 02:51 PM Wrote:ya, 15.2 I was getting lastnight, i have a tiburon it blew every little bulb in the thing, my alternator was overcharging, could this be the same thing??
[right][snapback]247444[/snapback][/right]
Don't alternators have a little clutch like device, similar to that used on an A/C? If so, maybe the alternator is stuck on.
did you try swapping out the battery? maybe the battery itself cant hold the charge
alright, figured it out, i put the meter on the battery in park, wiggled the 3 wires on the alternator, it ran rough, seems that when i swapped the motor, i didnt press in the plug far enough :angry: in a hurry i guess, so it must have threw the comp off. as well when i did it the meter went from 12v to almost 16! pressed it in all the way until it clicked! ran great...
I am having the exact same problem with mine I have had the problem for about 2 months biggest pain to drive in town. I will try that with the altenater hopefully thats it. If someone else could think of what it could be let me know.
howie321,Aug 23 2007, 09:02 PM Wrote:alright, figured it out, i put the meter on the battery in park, wiggled the 3 wires on the alternator, it ran rough, seems that when i swapped the motor, i didnt press in the plug far enough  :angry: in a hurry i guess, so it must have threw the comp off. as well when i did it the meter went from 12v to almost 16! pressed it in all the way until it clicked! ran great...
[right][snapback]247455[/snapback][/right]
NICE.. glad that's all it was
I totally lost track of this thread... good stuff!
