i have manual tranny and was wondering if anyone knew what the problem is if i have a spastic ebrake light its not a constant flash... anyone kno it tends to stop after about 80km/h or after bout 10 mins of driving...
Flashing And Dimming Ebrake Light
04-04-2007, 11:38 AM
girard.k,Apr 3 2007, 09:14 PM Wrote:i have manual tranny and was wondering if anyone knew what the problem is if i have a spastic ebrake light its not a constant flash... anyone kno it tends to stop after about 80km/h or after bout 10 mins of driving... Have your break cables checked. Get your self a brake inspection.
2000 ZX3
04-04-2007, 11:54 AM
Check your brake fluid. I had the same problem with the light flashing and then going off, then staying on. Turns out the clutch master cylinder went and it was drawing fluid from the brake reservoir and leaking it inside the cabin. Check the toe of your floor mats for brake fluid, mine had a spot on it.
It was covered under extended warranty for my car so I only had to pay the deductible. The brake light on the dash will come on when the fluid is low.
04-05-2007, 11:01 AM
guilty,Apr 3 2007, 08:54 PM Wrote:Check your brake fluid. I had the same problem with the light flashing and then going off, then staying on. Turns out the clutch master cylinder went and it was drawing fluid from the brake reservoir and leaking it inside the cabin. Check the toe of your floor mats for brake fluid, mine had a spot on it. That makes a tonne of sense ill check it out!!
04-05-2007, 02:51 PM
I had a bad wheel cylinder... and th fludi would get low wnough to trigger the sensor when I cornerd or used the clutch .... just another angle in case the aformentioned don't pan out
good luck AL ![]() I could List my mods.. my times and even my future mods here.. but there the same as yours.. with a little less conversation and a lot more action!
04-06-2007, 01:53 PM
ZED_not_zee,Apr 4 2007, 11:51 PM Wrote:I had a bad wheel cylinder... and th fludi would get low wnough to trigger the sensor when I cornerd or used the clutch .... just another angle in case the aformentioned don't pan out what do you mean by wheel cylinder?
04-07-2007, 11:27 PM
that happened to me once, good old ford wheel cylinder
My other ride is your Mom
04-08-2007, 01:54 AM
girard.k,Apr 5 2007, 10:53 PM Wrote:ZED_not_zee,Apr 4 2007, 11:51 PM Wrote:I had a bad wheel cylinder... and th fludi would get low wnough to trigger the sensor when I cornerd or used the clutch .... just another angle in case the aformentioned don't pan out uh the wheel cylinder is the cylinder with a piston that pushe's out of bothe sides in between the shoes on your rear breaks to engage them (if you have drums that is) ![]() I could List my mods.. my times and even my future mods here.. but there the same as yours.. with a little less conversation and a lot more action! |
« Next Oldest | Next Newest »
A/C Light Flashing | muttsnutts | 4 | 2,750 |
08-15-2012, 01:06 PM Last Post: ZTWsquared |
Ebrake Light | Chromey | 7 | 2,982 |
07-12-2012, 11:18 PM Last Post: sonic_mikey |
Flashing Check Engine Light | Frost__2001 | 6 | 3,290 |
08-18-2006, 05:16 AM Last Post: Frost__2001 |
