03-28-2007, 10:51 AM
K, today my battery light came on......I checked the battery, altenator, starter, everything was good. I also checked for bad wires and fuses....again, evrthing is goo.....anybody got any ideas??
Battery Light
03-28-2007, 11:50 AM
(This post was last modified: 03-28-2007, 11:50 AM by SmokeBCBuDZ.)
redZX3,Mar 28 2007, 12:51 AM Wrote:K, today my battery light came on......I checked the battery, altenator, starter, everything was good. I also checked for bad wires and fuses....again, evrthing is goo.....anybody got any ideas?? When u say checked... did u actually load test the battery? or test your charging system?
VF Supercharger Kit (Stage 2) "I usually don't do this type of work." "I thought you were a professional driver?" "A different kind of driving.".
03-28-2007, 12:12 PM
Best case: You have a loose connection. Tighten everything up, especially the battery
Worst Case: A new Alternator is needed.
2000 White ZTS: retired 2012 Frosted Glass SEL: active K&N Filter.....
03-28-2007, 12:21 PM
Ya i had this happen to me, turned out to be a loose terminal connection on the battery.
Current
09 F150 SCREW 4X4 XTR Former Show Hella Magic Module Tail Lights, 17" Ford Racing EAP rims, 5% Rear, 20% Front Tint, Panasonic CQ7401 Deck, 2 MB Quart 10's, Alpine Components, Phoenix Gold 500.1 Amp Go Steeda Cold Ram Air Intake MBRP Exhaust (Gen 2), FK Coilovers, Hedman Header (Install Pending),FC Hi-Flo Cat (Install Pending),EBC Greenstuff Pads
03-28-2007, 01:50 PM
I load tested the battery, which is brand new it was okay. I am going to clean the battery posts and make sure that isnt the problem.....even though they did look pretty good tonight when I took them off
redZX3,Mar 27 2007, 11:50 PM Wrote:I load tested the battery, which is brand new it was okay. I am going to clean the battery posts and make sure that isnt the problem.....even though they did look pretty good tonight when I took them off Have the alternator tested. Aswell make sure the ground for your battery has a clean contact. And you dont need the alternator pulled out to do it. Have a midtronics test run on it. My work does it for free if you consider it.
2000 ZX3
« Next Oldest | Next Newest »
Battery Light | FocusGuy7476 | 10 | 5,045 |
08-14-2012, 02:46 PM Last Post: FocusGuy7476 |
Battery Light at high speeds | 2000zx3sct | 3 | 2,488 |
07-02-2012, 02:25 PM Last Post: ZTWsquared |
Battery light | arpaul15 | 5 | 3,440 |
08-10-2011, 06:20 AM Last Post: Riitm |
Battery Light Stays On | SVTZX503 | 16 | 4,982 |
02-06-2005, 11:30 PM Last Post: ThraxXx |
