Wagon Drop And Stop Upgrades Part 1 - The Drop
This weekend, I finally got around to installing the H+R coilover kit that I bought in September of '04. Here's a pic of the final result: [Image: 2007FocursDropandStop-0023_1.jpg]
Rest of the pics can be found here: http://s62.photobucket.com/albums/h103/ima...20-%20Part%201/
Up next, the stop upgrades: BAT big brake kit up front and BAT rear disc conversion on the back (also waiting since '04).
Old Ride: 2001 Malibu Blue MTX Street Edition Wagon
New Ride: 2010 Mocha Brown MT 2.0T Passat Wagon
Looks good man. I'm doing a 1.6" drop with KW springs. On a difficulty scale 1 being easy and 10 being hard what would you rate this mod?
VF Supercharger Kit (Stage 2)
SmokeBCBuDZ,Mar 26 2007, 08:05 PM Wrote:Looks good man. I'm doing a 1.6" drop with KW springs. On a difficulty scale 1 being easy and 10 being hard what would you rate this mod?
[right][snapback]232085[/snapback][/right]
Probably between 6 and 7. Fortunately, there were no stuck bolts. The biggest headache we had was with the spring compressors borrowed from Crappy Tire. They just never seemed to fit where we needed them, so it took a bit of maneuvering to get the springs compressed.
Looks great man, nice job.
2008 Taurus X to be modded.
Still The Weakest LinkBlush
Yeah I am thinking of doing it myself too so I was going to rent the compressor from Canadian Tire too. Kinda nervous about it. But I did the header so I think I can handle the suspension.
Love coilover, nice even drop!
JMS US spec front lip, Rieger R-RX side skirts, Rieger R-RX rear apron, European rear bumper, European tail lights, RPMlabs grill, Painted side mirrors cover, H4 HID kit, Lamin-X yellow fogs, shorty antenna, Loder1899 replica rear spoiler, weathertech window delfector, Injen short ram air box, FC UDP pulley, FC 65mm TB, Focussport race header, Focussport flex, magnaflow hi-flow cat, MBRP catback, SCT Xcal2, ford racing spark plug wire, Tein S-tech, FK Damper kit, Eibach rear camber kit, Focussport strut bar, Painted valve cover, TeamDynamic pro race 1.2 17", Kumho SPT 205/45/17, Hawk HP, brembo blank rotors, Russell SS brakelines, Motul dot 5.1, Recaro replica seats on Recaro seat base, KKM shift surround, In-dash 7" DVD player, Tein Damper-chi doll!!
Nice work, and I love the brake upgrade idea. Well done!
Low sporty wagons make me happy :)
*thumbs up*
i just bought a strut spring compressor from Princess Auto for 20$, and it worked perfectly. you guys got Princess Auto out east right?
alone i swapped my suspension this weekend in 7 hrs., its not too hard if you've done it before. If you havent be sure to follow a how-to. you dont wanna screw up with springs in compression.
and i like the low wagons they look great, you dont see many
'04 liquid grey ZX3 - my FSP auto-x car
'02 infra-red SVT  - my street car, now for sale
Hi, I have a 01 station wagon. I am just wondering what kinda spring compressor do you use? The one i have has hooks on both end of the center bar. when I compress them all the way in, the spring is still not short enough to get out.
I also tried the one that compress on both side of the spring and it's very hard to get compression while the bar is not block by the lower arm...
please give me a pointer. thank!
looks good!
+1 for liking the Street wagon drop. Looks good!
Ryan
Ryan and the Silver Sedan
[Image: 49951.png]
Looks good!
2000 White ZTS: retired
K&N Filter.....
awang44,May 22 2007, 04:27 PM Wrote:Hi, I have a 01 station wagon. I am just wondering what kinda spring compressor do you use? The one i have has hooks on both end of the center bar.  when I compress them all the way in, the spring is still not short enough to get out.
[right][snapback]239274[/snapback][/right]
We used the spring compressors that are available from the Canadian Tire loan-a-tool program. Sounds similar to the one you have. And yes, we had similar problems to what your describing, especially on the back. Once we had compressed the spring as far as we could, we muscled it out. It wasn't pretty, but it worked.
Once we had them out, we had a much easier time putting in the new springs, as we could set the height adjusters all the way down, put the springs in, and then move the adjusters up to the desired ride height (all the way up in my case).
Ivan MacKenzie.
You'll like the upgrade. I noticed less body roll? or shift on on/off ramps after changing out the stock suspension on my wagon.
  Vogtland Drop Pictures .. zx5power 34 10,248 01-26-2008, 10:18 AM
Last Post: naz
  Drop Now Outta Specs zx5power 4 1,921 01-25-2008, 10:03 AM
Last Post: zx5power
  Wagon Drop And Stop Upgrades Part 2 - The Stop imack 9 2,976 04-04-2007, 12:06 PM
Last Post: imack
  Gas Mileage Drop With Short Ram Krusty Driver 10 2,470 02-12-2007, 09:49 AM
Last Post: NefCanuck
  Install A Drop Kit! Help! Ottawa Region... focusonthis88 13 3,213 04-11-2005, 11:48 AM
Last Post: BerinG
  Still Not Happy With My Drop. ZX3TUNR 12 3,795 04-05-2005, 02:32 PM
Last Post: naz
