Manual Tranny Issues
Well here's the deal guys, even before it got cold out i started to notice that tranny was getting stiff when trying to shift into and out of gears. For instance, sometimes its very hard to get the shifter out of gear.
I'm wondering if anyone has experienced this problem and what they did to fix it. I'm contemplating flushing and replacing the tranny fluid, but before i go thru that i just wanna make sure i'm not wasting money. Also i'm hoping this isn't a huge problem like my tranny going, not really interested in spending the money to fix it.
Any advice you guys might have would be great.
Thanks.
Current
09 F150 SCREW 4X4 XTR
Former
Show
Go
habmann,Mar 5 2007, 09:14 PM Wrote:Well here's the deal guys, even before it got cold out i started to notice that tranny was getting stiff when trying to shift into and out of gears. For instance, sometimes its very hard to get the shifter out of gear.
Thanks.
[right][snapback]229033[/snapback][/right]
Mine is the same but its not so bad in the warm. Dunno.
How many K on your car depends on wether you should flush or not.
Might consider a drain and refill rather then a flush.
Put some lucas transmission fluid in with it to :)
2000 ZX3
I'm at 131,000 in change.
And mines like yours not as bad in the warm, but still i think i need to do something about it.
Current
Former
Show
Go
ahh yes this is typical the fluid is warn down.. also the shifter cables where and sttretch a litlle making it a little bit harder when the fluid is cold sludge...
Quick fixes:
do an adjustment on your cable linkages,, the white one is usally the culprate...
let the car warm up and drive it in third gear down your street instead of going to fourth this will keep the RPM's up in the tranny and warm things up
Also do a quick spot check on the tranny to see if there is anything in the way of the linkage that expands when warm and frees things up.. I used to have an AEM CAI and it got in the way of the linkage on the tranny
If you flush:
use GM syncro mesh... it works well in almost any manual is thiner and won't gum up as much when cold...
Cheers
AL
[Image: forumsig.jpg]
OH and if you do mess with the linkage adjustments DON'T let the little retainer spring pop out! It's an absolute basterd to get back in without taking the whol damn thing apart.. LOL
Ya like I figured, just gonna do a drain and fill.
2000 ZX3
  2012 Ford Focus Manual tranny? mo_focus 11 10,295 01-14-2011, 03:56 AM
Last Post: GFXjamie
  Manual Tranny ? Parts zx5power 10 4,041 07-10-2007, 10:19 PM
Last Post: zx5power
  Manual Tranny Fluid brucktown 7 2,833 05-30-2006, 12:57 AM
Last Post: nass
  Manual Tranny Oil Change prezzx3 9 3,721 06-22-2005, 01:50 AM
Last Post: Focus Is Art
  Tranny Issues focusnme 9 3,741 06-13-2005, 10:43 AM
Last Post: ANTHONYD
  Focus Manual Tranny Fluid PHAT_ZX3 2 1,829 06-22-2004, 05:20 PM
Last Post: ZX3TUNING
