Manual Tranny Fluid
Has anyone changed theirs? If so how much did it cost? and did you use redline?
brucktown,May 26 2006, 02:47 PM Wrote:Has anyone changed theirs? If so how much did it cost? and did you use redline?
[right][snapback]189787[/snapback][/right]
Changed it? Yes. Used Redline? At first yes, but did not like it much so went to the Ford Full Synthetic Manual Trans fluid. The Ford fluid is much better, IMHO.
Old Ride: 2001 Malibu Blue MTX Street Edition Wagon
New Ride: 2010 Mocha Brown MT 2.0T Passat Wagon
[right][snapback]189828[/snapback][/right]
After how many Km's are you suppose to change it? and how much does it cost if you have crappy tire or jiffy lube do it?
[right][snapback]189837[/snapback][/right]
AFAIK there is no change interval specified. The only reason I changed mine was that the shifter got very stiff in cold weather. I changed it myself, so I don't know how much Jiffy Lube or Canuck would charge.
for what its worth, i personally wouldn't put anything other than the OE gear oil into the trans
I change my own. It's easier with a friend but you can do it solo. I use GM SyncroMesh fluid lots of guys on FJ seem to like it and I have to agree. Puts that tractor noise to rest for a while too :)
***want to buy***
MBRP................ check
SCT Xcal2 ........ check
VF mounts
Adj. Dampers ... check
Meford's Mom.... sale pending
nass,May 27 2006, 10:34 PM Wrote:I change my own. It's easier with a friend but you can do it solo. I use GM SyncroMesh fluid lots of guys on FJ seem to like it and I have to agree. Puts that tractor noise to rest for a while too :)
[right][snapback]189920[/snapback][/right]
bingo
260000km and counting.....
bingo
[right][snapback]190171[/snapback][/right]
You use it too? too bad it's pretty expensive :( Last time I changed it I put a tad more fluid in and it put the gear roll over noise completely to rest. I am a bit more cautious to try that in the summer, I don't want to blow a seal with the summer heat and too much fluid :(
***want to buy***
VF mounts
  2012 Ford Focus Manual tranny? mo_focus 11 10,027 01-14-2011, 03:56 AM
Last Post: GFXjamie
  Manual Tranny ? Parts zx5power 10 3,947 07-10-2007, 10:19 PM
Last Post: zx5power
  Manual Tranny Issues habmann 5 2,566 03-07-2007, 01:57 AM
Last Post: Mason
  Manual Tranny Oil Change prezzx3 9 3,645 06-22-2005, 01:50 AM
Last Post: Focus Is Art
  Tranny Fluid wadem 2 1,427 09-22-2004, 04:31 AM
Last Post: SLIP STREAM SVT
  Focus Manual Tranny Fluid PHAT_ZX3 2 1,773 06-22-2004, 05:20 PM
Last Post: ZX3TUNING
