06-06-2010, 11:16 PM
I changed my Springs again... Issue Is, My front left strut Wont tighten, The Main Bolt just spins with the Shaft.
Is this a broken mount.?
Suspension Question
06-07-2010, 12:13 AM
(06-06-2010, 11:16 PM)Chromey Wrote: I changed my Springs again... Issue Is, My front left strut Wont tighten, The Main Bolt just spins with the Shaft. You can stop the shaft from turning by putting the appropriate screwdriver or bit right into the top of the shaft - you can then use an open wrench to tighten the nut. The shaft spinning is fairly normal - it's no indication of anything broken.
06-07-2010, 02:02 AM
might be what i forgot to do this time... LOL Ill check.
This is my 4th set of springs... I hate spring sag.
06-09-2010, 02:58 AM
you will need to use allen key to stop shaft from spinning..
do not use hex, it will damage and you will end up using vice grip.. BLACKBOX(DASHCAM) | LED | HID | REMOTE STARTER + SECURITY | 12 VOLT ACCESSORIES | CAR ENTERTAINMENT | PERFORMANCE UPGRADE | MAINTENANCE REPAIR
![]() info@motormaniac.ca | 905.508.3737 If you are calling after hours, please leave a pm or detailed voice mail and we will get back to you as soon as possible.
06-09-2010, 03:38 AM
« Next Oldest | Next Newest »
Front Suspension Question | muttsnutts | 19 | 7,261 |
09-09-2012, 11:03 AM Last Post: muttsnutts |
Suspension question. | Focus man. Focus. | 13 | 5,104 |
05-13-2011, 09:03 AM Last Post: GFXjamie |
suspension question | blue_light | 6 | 4,039 |
02-12-2011, 10:44 AM Last Post: ZTWsquared |
Svt Suspension Question......help | imncrxtc | 29 | 11,160 |
12-08-2009, 08:25 AM Last Post: NikiterZTS |
Aftermarket Suspension/brakes/ Endlink Question. | darkpuppet | 4 | 2,304 |
01-22-2005, 12:45 AM Last Post: darkpuppet |
