Valve Cover
I did my valve cover gasket today, I've read here in the How to's and on FF that a 10 mm socket is require for the bolts on a Zetec. Mine has 8 mm's. I'm curious if anyone would know why the difference, or was it a typo error in the How to section.
2000 White ZTS: retired
K&N Filter.....
dunno IVe got three Zetecs one in my car... the otehr two on stands and they all have 8mm valv cover bolts
[Image: forumsig.jpg]
ZED_not_zee,Mar 26 2007, 03:29 AM Wrote:dunno IVe got three Zetecs  one in my car...  the otehr two on stands and they all have 8mm valv cover bolts
[right][snapback]231966[/snapback][/right]
must be a typo error.
K&N Filter.....
i need to do mine aswell cuz im pissing oil everywhere and its burning like a mofo...just how much did it cost you and can it be done at home
[img]http://www.focuscanada.net/images/fc_logo_black.gif[img]
Ya this can definately be done in your driveway no problem. As far as cost, the only thing you've gotta get is the gasket and i think its around $40 or so.
Current
09 F150 SCREW 4X4 XTR
Former
Show
Go
most bolts are 10 mm, but you will find the odd 8 and 9 mm ones too. the valve cover ones are def 8 mm though.
'05 Grand Cherokee LTD Hemi
ZTS_DJ,Mar 27 2007, 04:09 PM Wrote:i need to do mine aswell cuz im pissing oil everywhere and its burning like a mofo...just how much did it cost you and can it be done at home
[right][snapback]232187[/snapback][/right]
It's a pretty easy job. But, before you do it, check the bolts on the cover and tighten them down if they are loose. The oil was leaking out of one side more than the others. and that bolt was pretty loose. The gasket, when I got it off looked good, but ,once it's off, it's better to replace it.It cost me $63.00 at Ford. They'll need to know the manufacture date of your car.
K&N Filter.....
  Replacing Valve Cover Gasket habmann 15 7,697 04-10-2006, 04:08 AM
Last Post: Drivesthebeast
  You Might Want To Check.. Water Under Valve Cover DanielB_ZX3 14 6,280 08-24-2005, 02:57 PM
Last Post: ZX3TUNR
  Valve Cover Torque Tantrik ZX3 3 1,852 04-30-2005, 06:47 AM
Last Post: FocusGuy7476
  Valve Cover Gasket Medicman 9 3,790 01-02-2005, 10:31 PM
Last Post: Zoom
