04-30-2005, 01:49 AM
Does anyone know what the torque is for the valve cover? I can't find it anywhere.
Valve Cover Torque
04-30-2005, 02:08 AM
Haynes Repair Manual : valve cover bolts 80 in-lbs
For comparison, 80 in-lbs is HAND TIGHT in comparison as long as you are not cranking on it so if you don't have a torque wrench, go by that.
04-30-2005, 06:20 AM
The Ford shop manual says the same: 80 lb-in. or 9 Nm.
04-30-2005, 06:47 AM
just tighten it by hand by putting the very top of the rachet and turn it till its tight. don't use the handle of the rachet.
'03 Focus SVT
« Next Oldest | Next Newest »
Valve Cover | oldeguy | 6 | 2,097 |
03-28-2007, 12:06 PM Last Post: oldeguy |
Replacing Valve Cover Gasket | habmann | 15 | 7,723 |
04-10-2006, 04:08 AM Last Post: Drivesthebeast |
You Might Want To Check.. Water Under Valve Cover | DanielB_ZX3 | 14 | 6,288 |
08-24-2005, 02:57 PM Last Post: ZX3TUNR |
Valve Cover Gasket | Medicman | 9 | 3,802 |
01-02-2005, 10:31 PM Last Post: Zoom |
